Post by roverp5saloon on Jun 10, 2006 18:04:55 GMT
Hi, does anyone have a good idea how to stop the wooden surround on a rear window from creaking? Mine's a 1970 Saloon
Thanks Peter
Post by Phil Nottingham on Jun 10, 2006 20:01:02 GMT
Never heard of this - the joints must be loose?
Otherwise try adjusting the door striker/hinges unless the siils/D posts are past their best?
Post by roverp5saloon on Jun 11, 2006 10:17:42 GMT
Thanks, The joints aren't loose. The bodywork also is in good condition. I think the problem is the wood rubbing against the metal door frame. Is there any way of "sealing" the gap between the wood and the metal? Odly enough the problem only affects the one door. My mechanic suggests taking the door apart and sticking the wood down which would take 2 hours and cost a fotune. Peter
Post by RichardF on Jun 11, 2006 12:48:30 GMT
I've got the same problem with the rear right door - creaking most of the time. It is definitely the wood causing the problem on mine, so I intend to remove the wood and smear the adjoining faces with silicone grease and refit.
Richard Southampton
Post by stantondavies on Jun 12, 2006 7:05:21 GMT
The wooden door surrounds should be bedded on dum-dum which used to be available in tins, though I haven't needed any for some years. It deadens sound. I see there is some for sale on Ebay:http://cgi.ebay.co.uk/DUM-DUM-PASTE-SMALL-TIN_W0QQitemZ8053279339QQcategoryZ30923QQcmdZViewItem 8053279339
Post by rov5b on Jun 14, 2006 8:14:45 GMT
I can remember on the P4 Rovers, they had a thin material - similar to felt glued to the back of the woodwork - I believe this was for the same problem.
