Post by Deleted on Jul 7, 2006 12:19:11 GMT
Hi, time has come to sort out my coupe doors, I did 2 of them a few years back with Wadham's trim line panels but he no longer sells them (at least not for a long while anyway) does any body know another source for good quality repair panels?
I need drivers side front and rear.
thanks!
Will
Post by Phil Nottingham on Jul 7, 2006 15:48:20 GMT
Ray Weekly?
Post by Deleted on Jul 7, 2006 16:07:11 GMT
ok cool I'll give him a call!
thanks
Will
Post by Deleted on Jul 13, 2006 10:37:46 GMT
He doesn't do them either, does nobody produce them anymore?
Looks like I may have to undulge in a bit of panel beating!
Post by Smallfry on Jul 13, 2006 21:02:31 GMT
If the doors only had a single curve it would be a doddle, but sadly they do not.
I tried reskinning a front door with a piece of flat sheet and it looked OK until it was painted. It was then obviously wrong !
Good luck !
Post by Deleted on Jul 18, 2006 15:45:42 GMT
Ah, that could be the fly in the ointment them, haven't got an english wheel sitting around so a compound curve could prove difficult!
Looks like I may have to do the lower part panel repair then, wonder why nobody does the trim line panels anymore...
Post by Smallfry on Jul 18, 2006 20:53:06 GMT
I agree Will. The bottom repair seems a stupid idea to me, as its very difficult to acheive a good result without distortion and lots of filler, not to mention introducing either a stepped joint or a weld line low down where it can quickly corrode from the inside.
Under the trim strip seems more of a natural place to me, and also helps to conceal the joint.
