roverp5b
whats in your mirror
Post by roverp5b on Feb 18, 2018 11:54:27 GMT
Hello people, Just a quick update on my ongoing little problem, I have flickering headlights side lights and also noticed my yellow choke light flickers also which leads me to think the whole electrical supply is fluctuating! checked the earth connectors for lights as previously mentioned and they all seem fine. Could it be an alternator or another component breaking down? All stems since restoration work to the front end if that's a clue although as we all know that may just be a coincidence. Thanks Sean.
Post by Phil Nottingham on Feb 18, 2018 14:01:29 GMT
Battery earths are always a problem. Check the body to engine and especially the battery to boot floor. Then check the starter motor/solenoid connections
roverp5b
Post by roverp5b on Feb 18, 2018 15:24:24 GMT
Battery earths are always a problem. Check the body to engine and especially the battery to boot floor. Then check the starter motor/solenoid connections Thanks Phil I’ll have a look at those.
