Post by PatMcCoy on Dec 1, 2006 2:13:58 GMT
Does the Furflex lean in to the car or lean out to the door when fitting
Post by Phil Nottingham on Dec 1, 2006 17:11:37 GMT
Neither
Post by PatMcCoy on Dec 1, 2006 20:02:43 GMT
Neither? When i look at it,its like a p shape Does it sit in towards the interior or out to the door
Post by Phil Nottingham on Dec 1, 2006 20:06:51 GMT
True Furflex is a round rubber tube that has Coach lacing "Furtex" tape wrapped round it and sewn. As such it sits in the middle. If you like its 2 P shapes back to back.
If yours is the other version which Rover did not use, then it woukld make sense to have to outwards IMHO?
Post by PatMcCoy on Dec 1, 2006 21:15:00 GMT
If you like its 2 P shapes back to back? Anyone got a photo of furflex on a car and off please
Post by johnwp5bcoupe on Dec 1, 2006 22:42:57 GMT
Post by Phil Nottingham on Dec 1, 2006 22:54:12 GMT
Sorry I cannot seem to make this clear - have you got the type with with a P shaped rubber inside or just the round tube.
The round tube sometimes looks P shaped as its the way it comes out the sewing machine (some is even glued) - whichever way its put on it will lie the way the internal trim backing it pushes.
The other type has true P shaped rubber inside which has to be put so that the rounded side buts up against the door. All my cars have the the original stuff still on although I have replaced half that on the Coupe with new of identical type. My P2 has a mixture of both shapes!
I will see if I can get some pictures posted
Post by PatMcCoy on Dec 2, 2006 1:24:19 GMT
Thanks John I thought it did but the sprayer pulled it all off when spraying And i take it its the same as the original ? DESCRIPTION: Rubber tube covered with 100% wool pile. Tack on flange. Diameter: 9/16" (1.4cm). Flange 3/4" (1.9cm) USE: Popular seal. Fits Jaguar E-Type, Rover, Citroen, old Fords, Austin Healey, etc. COLOURS: Black, Red, Beige, Grey, Navy, Midnight Blue, Green, Suede Green, Brown, Cinamon.
Post by johnwp5bcoupe on Dec 2, 2006 7:24:15 GMT
Your on your way now Pat when you do the ends which are visible on the centre pillar if you carefully peel back the wool from the rubber about 1/2" cut the rubber tube to that point, cut off the tack strip the same amount then stuff the 1/2" of the wool down the tube hole with a small screwdriver, you will end up with a solid looking end! if it's a saloon of course you don't have to bother
Post by Phil Nottingham on Dec 2, 2006 9:18:05 GMT
Post by Deleted on Dec 2, 2006 14:10:49 GMT
How is the furflex treated at the top of the centre pillar? Any pics?
Post by Phil Nottingham on Dec 2, 2006 15:25:44 GMT
The inner tube is cut slightly shorter and the fabfric ends tucked in
Post by Deleted on Dec 2, 2006 17:47:12 GMT
Is that into itself or behind the garnish?
bigandy
Post by bigandy on Dec 2, 2006 18:26:12 GMT
garnish?
big a
Post by Phil Nottingham on Dec 2, 2006 18:38:39 GMT
Actually into itself and partly behind the cover
Post by johnwp5bcoupe on Dec 3, 2006 0:32:16 GMT
I did my best to explain Your on your way now Pat when you do the ends which are visible on the centre pillar if you carefully peel back the wool from the rubber about 1/2" cut the rubber tube to that point, cut off the tack strip the same amount then stuff the 1/2" of the wool down the tube hole with a small screwdriver, you will end up with a solid looking end! if it's a saloon of course you don't have to bother
Post by PatMcCoy on Dec 3, 2006 2:43:18 GMT
Cheers John
Post by Deleted on Dec 26, 2006 19:59:55 GMT
Pat, come and have a look at my furflex i have just put on, it looks the dogs danglers .Northen Phil.
Post by PatMcCoy on Dec 27, 2006 2:05:46 GMT
Oh yeah come and have a look at my interior lights They are nice an bright
Post by Deleted on Apr 1, 2007 16:41:05 GMT
Is that into itself or behind the garnish? I mean the cover. Sometimes called garnish. Not to be confused with Hellmans. ;D
