bigandy
Post by bigandy on Jan 24, 2007 13:50:31 GMT
feel real stupid but how do you get the cards and wood off? andy
Post by Phil Nottingham on Jan 24, 2007 17:12:58 GMT
Coupes and saloons are different but both start with removing the arm-rests 4 big Philips screws - make sure the large thich spacing washers do not get lost - then remove the handle circlips by hooking a bent wire (like stiff choke cable) behind the levers when upright.
The door cards just pull off using a wide chisel scraper behind - be careful not to tear the hardboard and covering. The door frame/wood fixings will then be apparent
When replacing make sure the polythene is not damaged otherwise water will damage the trims as most have been
Post by glennr on Jan 24, 2007 17:15:09 GMT
bigandy
Post by bigandy on Jan 24, 2007 17:49:37 GMT
cheers guys
a great help missed those small ones under arm rest
big andy
