Post by johnwp5bcoupe on Mar 5, 2007 9:27:09 GMT
Was the tunnel cover always the same colour as the carpet? it is a strange material a cross between carpet and Moquette!
Post by Phil Nottingham on Mar 5, 2007 9:46:26 GMT
Yes it was - the material is like a very thin version of the carpet which is not replicated by the kits that can be bought although the colour match is good
Post by johnwp5bcoupe on Mar 5, 2007 12:30:38 GMT
Thanks Phil the original stuff would be a lot easier to work around the corners I think and as you say it is a much shorter pile so it will have to look a little plush I got the carpet binding from Woolies it is a bit too narrow and the wrong pattern so I have ordered a sample of the Coach Lacing www.woolies-trim.co.uk/pc-1460-135-coach-lacing.aspxit's a bit toooo wide but I can loose that it looks right in the picture but I will see, I can't find the correct stuff
