taz
Post by taz on Mar 17, 2007 1:30:05 GMT
Hoping someone can help... I'm trying to remove the furflex on my P5BSaloon. The manual is not very helpful on removing the parcel shelf and crash rail. Can someone help me with some tips?
Thanks in adv, Taz.
Post by glennr on Mar 17, 2007 7:26:14 GMT
The parcel shelf should just lift out. I removed the two small side panels. (one by the clock and one by the handbrake) A large flat screwdriver can be used as they are held in with two clips each. The parcel tray is split in two sections. The large section on the left and the small section to the right of the steering column. The crash/bumper bar is held on with seven (i think, maybe more) 8mm nuts and washers. The one by the handbrake was fiddly. Good idea to have a magnetic screwdriver as they can drop off into the recess that accomodates the nuts. It should then lift off. The chrome strip is held on with screws which you can see when it is removed.
Post by johnwp5bcoupe on Mar 17, 2007 9:36:10 GMT
I recon those good informative instructions must be fresh in your mind Glenn
Post by glennr on Mar 18, 2007 21:29:26 GMT
They sure are John boy ;D
taz
Post by taz on Mar 19, 2007 1:36:22 GMT
Thanks guys
very helpful.
