Post by johnwp5bcoupe on Apr 11, 2007 16:27:56 GMT
Anyone know how the origonal feed to the headrests is run from the front console? or the rear heater control? and how are the curly leads connected to the wiring loom?
Post by Phil Nottingham on Apr 11, 2007 16:51:50 GMT
No, but I have seen some awful attempts at doing this - there is supposed to be a plug/socket affair at the seat base, have you got this?
Post by johnwp5bcoupe on Apr 11, 2007 17:11:40 GMT
No Phil this is an add on but I would like to do it properly
Post by johnwp5bcoupe on Apr 14, 2007 13:23:02 GMT
I found the info in the 3lt parts book it shows the headrest being fed from the front then into a standard block connector! can anyone tell me where the block is situated?
Post by jlalexander on Apr 14, 2007 13:40:32 GMT
the headrests'lights are fed from the cigar lighter feeding wire. There is a twin blade male socket that connects to a female which has a housing in the headrest support in the back seat. The wire is then routed through the side hinge trim with a very small grommett; it's going then under the carpet, under the gearlever casing and finally to the connection on the cigar lighter feed. ( my car had the headrests' lights fitted by a Rover dealership in 1972 with a factory kit) The wires are black.
Post by johnwp5bcoupe on Apr 14, 2007 13:52:05 GMT
Thanks for that John I have all the plugs and sockets do the two headrest leads combine before going to the front connection?
Post by jlalexander on Apr 14, 2007 14:59:00 GMT
yes they join a little before the connection to the fog lights switch feed ( I mentioned the cigar lighter by mistake) This way, they work only when the lights are on.
Post by johnwp5bcoupe on Apr 15, 2007 6:14:40 GMT
Ok thanks John, there are two spare bullet connectors R/W wire and a Black at the same point as the R/W feed to the bulb for the Gear Shift Lever, I think that is where they must feed from.
Post by Phil Nottingham on Apr 15, 2007 9:31:19 GMT
That would seem to be the logical place but I doubt it, as then the head rest lights would be under the dimmer panel light control and thus all the panel lights would have to be on at full brilliance. This may or not matter of course as I am not certain whther anyone actuall uses these devices anyway!!
