Post by Warwick on Oct 7, 2019 12:55:07 GMT
How about we call this topic, "what have you done to your P5 today." ........ I'll tell you what I did on mine today. Same thing I did yesterday, and the month before that, and the 6 years before that. B****r-all. (We'll see what the ProBoard's robo-censor makes of that!)
Post by Warwick on Oct 8, 2019 12:01:20 GMT
Thanks John, Vince, and Brendan. While I appreciate your LIKES for my post, I am quite surprised by them. But after searching the forum, I have discovered your conundrum; there is no DEPLORABLE button. David, can you rectify this?
Post by David on Oct 8, 2019 12:12:00 GMT
Title now sorted to cover all possibilities/flavours. As for the button Warwick... sorry, cannot be done!
Post by stirlingmg on Oct 8, 2019 19:46:17 GMT
Got the underbonnet lights working (could do with new lenses), replaced all 4 interior lights & connected them properly so they work as they should, got the brake warning working, got the rear heater light working, tested the boot light circuit & that all works but I haven’t got a bulb, stripped & cleaned the number plate/ reverse lamp assembly. Who says the light nights are finished?
Post by enigmas on Oct 9, 2019 10:41:34 GMT
Did some more mechanical maintenance on my MK3 coupe. There was an odd ball sensation when taking off from stationary at various times and load...sometimes felt like a judder and at other times like a restrained knock. It turned out to be a loose centre bearing support for the tailshaft! Under torque it would rotate/lift slightly on it's rubber mounts causing misalignment (out of phase issues) of the tailshaft. * Ahh! the dreaded centre bearing support rears it's ugly head. Definitely worth checking if you've never gone there!
Post by stirlingmg on Oct 9, 2019 20:32:02 GMT
One tiny little job tonight, replaced the bonnet safety catch, then took the car along to the local cafe for the Wednesday night car meet
Post by stirlingmg on Oct 10, 2019 21:36:46 GMT
Poor starting & unwillingness to idle has been my project for tonight. Starts & ticks over lovely now at the expense of poor running higher up the Rev range, further tickling required. Also fitted my rather crude but cheap & effective electronic ignition which made it a lot smoother
Post by stirlingmg on Oct 11, 2019 19:25:19 GMT
Hmmmm it’s even worse to start from cold now, I think I might order a couple of repair kits for the carbs. Disappointed with that, I turned to less frustrating jobs & repaired the wiring to the n/s/f side repeater as it had dropped off the back of the lamp, it was fun feeding the wires back through the wing, in the end I pulled them back through into the car & fed a length of brake pipe through the wing and through the grommet hole behind the kick panel & fed the wires through the pipe then soldered them to the lamp. I’m awaiting parts now so I can do some further improvement work so while i’m waiting I think the next job is to complete the carpet install that the previous owner had made a start with
Post by stirlingmg on Oct 13, 2019 22:16:02 GMT
Had a bit more fiddle with the carbs & found it seems to overfuel massively on the l/h carb, removed it, stripped it & found nothing obvious...............annoying
Post by djm16 on Oct 13, 2019 23:00:29 GMT
Re the underbonnet lights, the complete units are available from Wadhams, Moss etc. They are however the wrong bases for the P5. You can use the clear dome though on your existing units.
Post by stirlingmg on Oct 14, 2019 5:38:12 GMT
Thanks for that
Post by lagain on Oct 14, 2019 18:09:25 GMT
I took my differential to Hardy Engineering at Leatherhead to have it checked over. Another member took his diff to them and they replaced all the bearings and shims where neccessary. Have been able to polish the inside of the casing
Porky
Post by Porky on Oct 15, 2019 7:29:07 GMT
Had my gearbox done by these chaps earlier this year, top job. I took my differential to Hardy Engineering at Leatherhead to have it checked over. Another member took his diff to them and they replaced all the bearings and shims where neccessary. Have been able to polish the inside of the casing
Post by Sam Bee on Oct 15, 2019 18:42:23 GMT
Nearly as clean as mine, matey!
Post by stirlingmg on Oct 15, 2019 20:22:19 GMT
Well if it ain’t broke, fix it until it is...............that’s the way it’s been for me this last few days. After my carb fiddling failed to make the car run any better, if anything it got worse, I have come to the conclusion the electric fuel pump is overcoming the needle valve on the l/h carb. I spoke to Burlens who were very helpful & they agreed my theory is perfectly plausible, so i’ve ordered a carb service kit from them. Sadly it arrived today & was incorrect........of course I was forgetting the fact the aed has been removed and therefore the carbs are sporting adjustable jets instead of wax stat ones, another kit will be on it’s way shortly. Tonight I have disposed of the electric pump and it’s very unprofessional wiring with a view to reinstating the mechanical one. I just need the fuel pipe that runs from the pump up to the filter. One question though, when I reinstate the return line should it have a restrictor in the line or is the fact that it’s a much smaller bore pipe enough for it to prevent the fuel bypassing the carbs altogether?
Post by johnwp5bcoupe on Oct 15, 2019 20:52:35 GMT
You should have no problem with an electric pump Colin as long as it's max 4psi! the black spill return just leave as is.
Post by stirlingmg on Oct 16, 2019 7:10:34 GMT
No idea what pressure it’s running but sometimes it doesn’t shut itself off which tells me the fuel is going somewhere and it’s not coming out of the overflows, plus the thick black smoke out the back & the fact that it blackens plugs 1,7,4&6 points at the l/h carb being the culprit
Post by johnwp5bcoupe on Oct 16, 2019 8:32:13 GMT
No idea what pressure it’s running but sometimes it doesn’t shut itself off which tells me the fuel is going somewhere and it’s not coming out of the overflows, plus the thick black smoke out the back & the fact that it blackens plugs 1,7,4&6 points at the l/h carb being the culprit Colin I would double check the float settings and set them as per manual before doing anything, adjust your jet so it's flush with the carb body if it still floods check the float level again its a very critical setting!
Post by stirlingmg on Oct 16, 2019 12:27:12 GMT
The floats don’t appear to be adjustable on my carbs
Post by johnwp5bcoupe on Oct 16, 2019 13:16:19 GMT
The floats don’t appear to be adjustable on my carbs So you got the solid plastic ones? I have PM'd you Colin
Post by stirlingmg on Oct 17, 2019 20:40:29 GMT
Well it was all going very well tonight, l/h carb overhauled, r/h carb converted to choke and partly overhauled but the I knocked the piston off the bench and bent the needle
Post by Warwick on Oct 18, 2019 6:10:58 GMT
I feel your pain from over here.
Post by stirlingmg on Oct 18, 2019 11:24:13 GMT
I wasn’t best pleased with myself, I wouldn’t have minded so much but i’ve got 3 cars to service tomorrow after work and I don’t fancy lying in the muddy yard to do them
Post by johnwp5bcoupe on Oct 18, 2019 14:13:44 GMT
I wasn’t best pleased with myself, I wouldn’t have minded so much but i’ve got 3 cars to service tomorrow after work and I don’t fancy lying in the muddy yard to do them Sh1t happens Colin
Post by stirlingmg on Oct 18, 2019 15:43:47 GMT
Aye I know
