Post by johnwp5bcoupe on May 30, 2007 9:51:39 GMT
Post by glennr on May 30, 2007 12:58:42 GMT
Sorry to hear about the elbow The carpets do look excellent John and I appreciate the amount of work that is involved.If you say you would rather make 4 sets of door cards as one set of carpets then it must be a cow son of a job to undertake
Post by johnwp5bcoupe on May 30, 2007 18:36:51 GMT
I should have said painfully slow Glenn the Witch Doctor he say "rest it" anybody seen some fog to knit
Post by Multi-Tech on May 30, 2007 21:58:29 GMT
John a top looking job I take it you sorted the problem with the glue then? Look forward to seeing it all complete Oh and i understand how you feel and hope the arm gets better soon
Post by johnwp5bcoupe on May 31, 2007 6:20:27 GMT
Hi Barry thanks on both counts I went back to the same shop to return the spray glue and they had changed the product on the shelf, so I swapped the ones I had bought it worked great problen solved "The problem was some spray glues will not stick to so called rubber backed carpet because the Silicone content breaks down the glue and it just goes to Goooo"
Post by johnwp5bcoupe on Jun 1, 2007 17:26:41 GMT
Post by glennr on Jun 1, 2007 22:36:58 GMT
Well done John. An excellent job as always. ;D
bigandy
Post by bigandy on Jun 3, 2007 13:29:40 GMT
what is the material on the right hand side of the footwell by the accelerator? ? and where does one get it??? big andy
Post by Phil Nottingham on Jun 3, 2007 15:38:31 GMT
Its called Furtex and can be had from places like Woolies in various colours matching the the Furflex door edge trims
bigandy
Post by bigandy on Jun 4, 2007 11:03:00 GMT
thanks ill search forwoolies
bigandy
bigandy
Post by bigandy on Jun 4, 2007 11:30:45 GMT
done and ordered thanks
big andy
Post by johnwp5bcoupe on Jun 4, 2007 12:29:13 GMT
A bit of advice big andy if you stick the Moquette down dont try to pull it up again modern adhesives seem to melt the backing and all you will get if you pull it is the backing and the wool left on the board Back to carpet making
bigandy
Post by bigandy on Jun 4, 2007 19:17:39 GMT
thanks hope to do as nicer job as yours!
big andy
Post by johnwp5bcoupe on Jun 10, 2007 21:05:52 GMT
Finally finished the carpets ;D a step nearer to completion loads of pain killers later and I am still not playing tennis I used Coach Lacing for the carpet binding 35 meters of it you can dye it what colour you like! so it says on the suppliers web site I had yellow,red and purple at various stages with different dyes it was down to the colour being more gold than beige so Dylon informed me there is a process I found that works after wasting 4 lots of dyes, you can drop me an email if you want to know Next job is my rear seats and interior lights then thats the interior finished more or less s88.photobucket.com/albums/k163/johnwp5bcoupe/?action=view¤t=P1010258.jpg
Post by glennr on Jun 11, 2007 4:49:42 GMT
Might make the Eatern Rally then? Hard to believe the end is in sight ;D
Post by johnwp5bcoupe on Jun 11, 2007 5:35:33 GMT
I still have a lot to do Glenn when I stand back and take the Rose coloured glasses off "BUT" I will try to be there
Post by glennr on Jun 11, 2007 9:08:03 GMT
I have some good news on the carpet clips. He is going to price a batch of 100 and 200. They will be in stainless steel. I will keep you updated.
Post by johnwp5bcoupe on Jun 11, 2007 9:54:45 GMT
That sound promising on the clips Glenn I am sure a lot of guys will want them save staining the carpets
Post by johnwp5bcoupe on Jul 12, 2007 19:51:44 GMT
One more area conquered sticking the newly made wheel arch covers was not easy I made them exactly to pattern still a B to fit and stick I made all new panels as the old ones were a bit warped just got to clean the mat and fit the seal, get the shroud cover and that the back end done ;D I should ge my SS exhaust in a week or so trying to do some bit's on a friends P5b at the same time before the exhaust arrives ;D s88.photobucket.com/albums/k163/johnwp5bcoupe/
Post by Deleted on Jul 13, 2007 7:35:54 GMT
It is possible also to refresh the boot trims by cleaning them and applying black upholstery paint - it works very well.
I have found that my rubber floor mat in the boot is beining to disintegrate, not surprising given its age!
Post by glennr on Jul 13, 2007 9:38:44 GMT
Nice job too! Looks like you are on target then!
Post by johnwp5bcoupe on Jul 13, 2007 10:06:16 GMT
I am trying Glenn Freddy the trims were all removed when the boot was sandblasted 10 years ago so new ones for the arches had to be made I have tried to remove some from another car nearly impossible dont know what they used to stick them but it worked well looks like Bitumen
Post by Phil Nottingham on Jul 13, 2007 19:02:36 GMT
It was theta old fashioned black Bostic - some come off esaily wiothout damage but others can be totally ruined - there seems no half way
Post by dorsetflyer on Jul 14, 2007 20:37:53 GMT
Yes the old black 'Bostic' adhesive was very good and long lasting. I can remember putting the Number of it on the old 'Board', but my memory has failed me. I know we used to use this in the Aerospace Industry in the 60/70's, and the first two digits began with either 15.. or 17.. I have probably got all the details up in my loft from those days.
Post by johnwp5bcoupe on Jul 14, 2007 21:32:10 GMT
It stuck well that's for sure
