Post by dhb5610 on Mar 11, 2019 17:43:15 GMT
Hello I'm looking for some help finding a good reliable and quiet electric fuel pump for my Rover P5B. I currently do have an electric pump in the boot near the fuel tank but it is quite old and a bit noisy although that could be due to it's location. I could use it as a secondary pump in the event of a new primary pump failure. So any suggestions please
Post by Phil Nottingham on Mar 11, 2019 18:04:23 GMT
Quiet and reliable do not go together but at the front Facet is only audible in idling
Post by johnwp5bcoupe on Mar 11, 2019 19:22:32 GMT
Quiet and reliable do not go together but at the front Facet is only audible in idling The sound of the Facet is reassuring Phil when you are nearing reserve as the rate of the pump increases, my pump is under the floor on the GB rail
Post by lagain on Mar 11, 2019 20:10:51 GMT
Post by Phil Nottingham on Mar 11, 2019 20:32:21 GMT
My deafness is getting worse and even with both hearing aids switched off I can hear the rear mounted pumps in the P4 and P5 Mini and now P2 ticking away at moderate speeds
Post by johnwp5bcoupe on Mar 11, 2019 21:49:45 GMT
Your right George 4 psi max
Post by lagain on Mar 12, 2019 19:12:00 GMT
Your right George 4 psi max Thanks for that confirmation, John, I was not quite sure. The pump I have on mine has been on for many years. I bought a Facet but thought it looked a bit cheap and did not like the connections ! So I bought one for a V8 Sherpa, which is a cylinder, in one end and out the other. No idea what the pressure is though, but it is very quiet.
Post by enigmas on Mar 12, 2019 22:50:04 GMT
Post by Phil Nottingham on Mar 13, 2019 18:06:00 GMT
That is one I had in our P5B since 2001
Post by Sam Bee on Mar 14, 2019 21:39:56 GMT
The answer to the fuel pressure output is to fit a pressure regulator downstream, as I have on my P6B. That can be adjusted to give optimum performance.
Minty
Post by Minty on Mar 21, 2019 13:21:52 GMT
Hi,
I've fitted 'Bearmach' Land Rover V8 electric fuel pump's (on rubber-exhaust bobin's) to the N/S inner-wing's of both my Saloon and Coupe' and I've found them to be very reliable, quiet and easy to fit...their cheap too, at around £25.00 each...their unobtrusive, whilst having a 'period-correct' look about them too...
Whilst they can be heard quietly 'ticking-away' when the ignition is switched on, once the engine is running, they can't really be heard at all.
For info, the Bearmach Part No is: PRC3901 and they can be bought from most decent Land Rover part suppliers.
Kind Regards,
Guy.
Post by Roy of the Rovers on Mar 21, 2019 13:25:35 GMT
Fit a cherry bomb .... no more listening to the noise of the fuel pump
