Post by Roy of the Rovers on Mar 29, 2019 12:25:12 GMT
Hi, just a quick question to see if people have a preference. Its a general question that could apply to a Rover V8 engine or any engine. In my case it will be a jag 3.8 engine.
If an engine has not been run in many years (9 years) which is best to pour down the spark plug holes initially? I want to make sure I don't damage the pistons and bores before I try and turn the engine and start it. 1) WD40 2) Diesel 3)A.N. Other
What is your experience?
Post by Warwick on Mar 29, 2019 13:30:53 GMT
Automatic transmission fluid.
Post by Roy of the Rovers on Mar 29, 2019 14:10:08 GMT
Automatic transmission fluid. Better than the other 2 or was it just what you had laying around warwick?
Post by johnwp5bcoupe on Mar 29, 2019 19:09:22 GMT
Automatic transmission fluid. Or Diesel
Post by enigmas on Mar 29, 2019 21:31:02 GMT
I'm with Warwick on the ATF. It's designed to lubricate and operate within the fine tolerances of a transmission's valve body as well as having other beneficial properties.
Post by Warwick on Mar 30, 2019 2:54:58 GMT
Automatic transmission fluid. Better than the other 2 or was it just what you had laying around warwick? If I had to store an engine for a long time, I'd pour ATF down the plug holes and just leave it. If it was an engine that was unknown and could have been dry for a long time and perhaps all gummed up around the rings, I'd use diesel first and leave it for a while. It's thinner than AFT and it's also a solvent. But I'd follow up with a good soaking with ATF before I tried turning it over.
Post by Roy of the Rovers on Mar 31, 2019 13:41:14 GMT
If I had to store an engine for a long time, I'd pour ATF down the plug holes and just leave it. If it was an engine that was unknown and could have been dry for a long time and perhaps all gummed up around the rings, I'd use diesel first and leave it for a while. It's thinner than AFT and it's also a solvent. But I'd follow up with a good soaking with ATF before I tried turning it over. I used gearbox oil as I didnt see your other reply. I’ll leave it in there for a week before trying to turn it over. Fingers crossed
Post by Warwick on Apr 1, 2019 9:48:33 GMT
Should work okay, Roy. The main advantage of ATF is that it's just as slippery, but much thinner. But a word of warning! Whatever you do, do not, I repeat, DO NOT, use orange juice. Even though it may taste better.
