Post by p5coupepaul on Jun 16, 2019 7:01:47 GMT
I need to replace my starter motor on my 1970 coupe. wheres the best place to purchase from please. is there any percific one that you would recommend cheers paul
Post by Phil Nottingham on Jun 16, 2019 20:12:18 GMT
Standard Lucas pre-engaged from the 60s-70s. David Green secondhand or various other car electrical reconditioners. If buying a replacement ensure the solenoid has the ballast shunt terminal if you have the 1968 separate coil shunt fitted.
See SEARCH for later compact geared high torque motors
Post by p5coupepaul on Jun 17, 2019 5:47:42 GMT
thanks for heads up phil
Post by Deleted on Jun 17, 2019 8:45:13 GMT
You can buy the solenoid seperately if thats all thats wrong. I found when replacing my starter that fitting/removing the solenoid seperately made the job much easier.
Post by begard on May 12, 2020 17:27:35 GMT
Solenoid Hi please see my post fe the above any help would be useful Thanks
Post by lagain on May 12, 2020 20:35:26 GMT
Some months ago there was a write up in Take Five by Geoff Arthur on a replacement starter motor and it was given 9 out of 10.
A Powerlite RAC 318 at about £200
The only problem is if you still have a ballast resistor in use as the Powerlite does not provide the 12 volt output to boost the coil voltage during start up. Easily solved by converting to a normal 12 volt coil that is powered from a live while cranking ignition connection or conversion to electronic ignition would be an even better solution but that will require a new coil at the same time. If you do not fancy that the connection can be taken from the starter relay via a diode or simple relay.
