Badges
Dec 3, 2007 20:28:54 GMT
Post by park01 on Dec 3, 2007 20:28:54 GMT
Hi All
i am putting my badges back on after respraying.Whats best to use for putting them on? i have thought about using a strong adhesive especially on the "3.5 Litre" badges (I don't have the little plastic clips). but i don't want them to be to difficult get off in case somebody tries to pinch them (ie they wont damage the paint work) i have thought about using the windscreen sealant?
many thanks Karl
Badges
Dec 3, 2007 20:42:44 GMT
Post by harvey on Dec 3, 2007 20:42:44 GMT
The proper widscreen adhesives will near enough tear a hole in the metal before it lets go, absolutely brilliant if you never want it to come off, but not good if you think someone might try to remove them.
Badges
Dec 3, 2007 21:32:25 GMT
Post by Phil Nottingham on Dec 3, 2007 21:32:25 GMT
Why just use two stripes of double sided trim fixing tape - this holds them reasonably tight. Scotch does one version but there are plenty of others although some domestic types are not waterproof or black
Badges
Dec 4, 2007 16:56:51 GMT
Post by p5tgc on Dec 4, 2007 16:56:51 GMT
Use the sticky pads sold for fixing number plates on, these are available in thin & thick versions and can be trimmed to size.
Badges
Dec 4, 2007 18:58:45 GMT
Post by Colin McA on Dec 4, 2007 18:58:45 GMT
The correct badge inserts are available from Ian at Rover classics in Doncaster. Colin Rover Classic 01777 816 600 www.rover-classics.co.uk/
