Post by glennr on Dec 18, 2007 23:16:16 GMT
Could anyone give me any other makes/models that would of had sill trims? not just Rover.
Post by Multi-Tech on Dec 18, 2007 23:30:49 GMT
I think some Mercs do
Post by glennr on Dec 19, 2007 0:02:32 GMT
Cheers Pricey, keep them coming I am looking to get a list in case there is a market out there I will then write to the classic car clubs to see what the response might be. 1. Mercedes 2.Pug 403, 404 3.Rolls Royce Silver Shadow 4Austin Princess 5.Renault 16
Post by Warwick (Ozcoupe) on Dec 19, 2007 3:46:35 GMT
Peugeot 403 and 404.
Post by Deleted on Dec 19, 2007 8:33:54 GMT
Rolls RoyceSilver Shadow 2
Post by Phil Nottingham on Dec 19, 2007 9:45:56 GMT
Austin Princesses do and Renault 16's Like the P5 not all models had them through entire production life.
The running board Rovers of the 1930's and 1940's had them as well but not as wide and they were on the running board vertical face
Post by glennr on Dec 19, 2007 19:02:34 GMT
Post by Phil Nottingham on Dec 19, 2007 22:08:40 GMT
Do not know about the 16 but some more cars of the 60's 70's which had them are the Rolls Royce Shadow 1 and Bentley V-P Princess 4 litre and some Farina Morris Oxfords. Volvo 166, Alvis TF21, Vauxhall VX 4/90 & Ventora (FC Victors) Mk3 Ford Zephyr 6 and Zodiac, Ford Zodiac Executive Mk4. Some Fiats and W German Fords including top of the range Mk1 Capri's. Mk3 Humber Sceptre (Arrow), Opels. There are probably more from the mid 70's eg Mk1 Granada Ghia's?
Quite a few to go at but as with P5B's a lot have long fallen off!
Post by Smallfry on Dec 20, 2007 1:01:54 GMT
Opel Mantas A and B and Sunbeam Rapiers. Vauxhall Viva HC, Firenza and Magnum.
Post by Warwick (Ozcoupe) on Dec 20, 2007 1:27:24 GMT
Any reason why you are focusing on sill trims Glenn? Door trim strips are of similar construction on many cars.
Post by glennr on Dec 20, 2007 7:48:51 GMT
Cheers guys.The list is growing.
Oz you are quite right but I have never had anyone request a wing/door trims. The sill trims seem to be the rare ones as they fell off due to their location.
Post by dorsetflyer on Dec 20, 2007 15:27:57 GMT
Glenn, some of the 16's had trim along the rear wheel arches, and one model had a short piece of trim on the waist line of the rear side panel.
Post by glennr on Dec 20, 2007 16:27:04 GMT
Cheers all. Any idea on the abnormal Renault 16 quarter panels
Post by Phil Nottingham on Dec 20, 2007 17:52:47 GMT
Ozcoupe - Sill strips are much rarer generally and all are car specific as they are generally one piece (P4 have wide separate ones like the 50'60's Mercedes) and have unique X section and end profiles. In the UK the sills quickly rust away taking the sill strip with.
DF - the Humber Sceptre Mk3 had arch trims as well on them!
Post by glennr on Dec 21, 2007 0:51:43 GMT
Post by Warwick (Ozcoupe) on Dec 21, 2007 1:35:59 GMT
Thanks Phil. I hadn't thought of the rust susceptibilty factor with sills.
Glenn,
This is stretching my memory back a bit. The R16 has torsion bar suspension and the bars are L-shaped. They are quite long and overlap across the car, one behind the other. Shorter bars would have prevented the characteristic French long-travel soft suspension of that time. (Like all proper French cars).
This causes the wheelbase on one side to be longer than the other. This has virtually no effect on ride and handling as the difference is not great, and many people never even noticed the visual difference.
The only other option would have been to overlap the bars one above the other. This would have kept the wheelbase the same but would have changed the suspension characteristics for each rear wheel.
Oh, and the other reason is because they're French. (And good on 'em too)
Post by glennr on Dec 21, 2007 6:49:23 GMT
Well OZ, you learn something new each day. Thanks for the explanation.
Post by dorsetflyer on Dec 21, 2007 14:21:09 GMT
I knew the French were an odd lot Glenn, this confirms it. Phil, I agree the MK111 Sceptre has wheel arch trims fitted, but they were polished aluminium alloy not stainless steel.
