Post by Multi-Tech on Jan 10, 2008 21:52:44 GMT
Our any of the window regs inter-changer able
I have a spare rear but the front one is playing up so was hoping i may be able to change some bits over
I also have a saloon reg will this fit a coupe?
Post by Phil Nottingham on Jan 10, 2008 22:10:25 GMT
No they are all different - the Coupe front winders are cheap and inadequate to carry the weight and drag of worn/wet window frame channels. Parts from the rear ones ie the small gear and I think the big 1/4 one can be made to fit the fronts
Post by Multi-Tech on Jan 10, 2008 22:30:45 GMT
Thanks for the quick reply Phil I will see if i can make some of the rear parts fit another job for the weekend
Post by Keith - Portsmouth on Jan 10, 2008 23:36:34 GMT
I rebuilt my coupe front driver's side using Frank's excellent guide. That thread mentioned that the actual core mechanism is the same on coupes and saloons. It also says that P6 mechanisms can be made to fit. Indeed, I used a P6 NSR mechanism to rebuild a OSF one.
Post by johnwp5bcoupe on Jan 14, 2008 11:22:44 GMT
Yes the gear mechanisms can be adapted from back to front but you will need a Mig Welder or David Green has them refurbished
Post by Phil Nottingham on Jan 14, 2008 16:49:31 GMT
and I forgot to mention SEARCH this time!! for a change
