Post by Deleted on Jan 27, 2008 20:44:31 GMT
Hi all i have got some new sponge for my front seat base what is it like to get the cover of to change the sponge
Post by Phil Nottingham on Jan 27, 2008 22:28:19 GMT
Its quite easy if you are careful and unclip all the clips around the bottom vynil section. Its actually glued onto the foam so this will have to be carefully scraped off. Now is the time to restitch any split seams. You need to remove the seat and all its stainless trims.
Its fixed to the back cover section as well
Post by Deleted on Jan 27, 2008 23:25:18 GMT
Thanks phil will be doing it tomorrow
Post by johnwp5bcoupe on Jan 28, 2008 6:28:05 GMT
It may be worth giving the Calico ties the once over vince just in case they have started to rot
