Post by bristol406 on Mar 9, 2020 21:02:44 GMT
To minimise any damage I'm looking for tips on removing the door cards on my P5B coupe. I need to inspect the window winding mechanism as the driver's window is extremely stiff to operate. I'm hoping it just needs a clean and lubrication or am I being far too optimistic !
Post by johnwp5bcoupe on Mar 9, 2020 21:10:20 GMT
To minimise any damage I'm looking for tips on removing the door cards on my P5B coupe. I need to inspect the window winding mechanism as the driver's window is extremely stiff to operate. I'm hoping it just needs a clean and lubrication or am I being far too optimistic ! Drivers side winders on a coupe are prone to failure, the Quadrant teeth fail due to the Cog Box either being rusted or lack of grease!
Post by Sam Bee on Mar 9, 2020 21:24:20 GMT
I have a tough plastic scraper that does the job without scratching paintwork whilst giving good leverage. Start at a corner, then slide along to each clip (by feel) in turn.
Post by bristol406 on Mar 9, 2020 22:06:44 GMT
Do the door handle and winder handle have circlips holding them on and how difficult are they to locate and remove ?
Post by djm16 on Mar 9, 2020 23:25:55 GMT
If I am remembering the correct car, there is a ring at the base of the door opener that slides outwards revealing a dowel through the the handle and square rod. You also need a set of panel trim removers such as: link
Post by Phil Nottingham on Mar 10, 2020 7:20:23 GMT
Just push the ring/spring and card back and use a bent still wire to hook out the wire clip the top of which is behind the actual lever. Early P5s had a dowel
Post by bristol406 on Mar 10, 2020 15:18:07 GMT
Thanks guys. Mine is a 1972 so probably no dowell. My son has a set of plastic trim removers that I can borrow.
