Post by cheese99 on Mar 10, 2020 11:33:16 GMT
Hi All,
Still awaiting my P5 so cannot examine. How difficult is it to change the gear selector indicator on the auto transmission. It's just refreshing the selector indicator plate so assume very easy? (probably easier than sourcing one - just got a newish one however in expectation).
(Wadhams did not have any in stock).
Post by lagain on Mar 10, 2020 18:23:05 GMT
It just unclips,but you need to unscrew the gear knob, easy !
Post by petergallagher on Mar 10, 2020 18:40:03 GMT
Hi gents, I removed the gear knob on my P5B over the weekend and found it held together with what appears to be windscreen sealant. I measured up what I think should be a spacer with the following dimensions: OD 3/4 ID 1/2” UNF By 5/8 long My idea is to glue this into the knob. Is this how the knob is supposed to be put together?
Post by harvey on Mar 10, 2020 18:51:30 GMT
A rubber fits inside the knob and cuts its own thread as it's screwed on to the lever. You can use a suitably sized piece of rubber hose, as that's what the suppliers will sell you if you buy one from them
Post by lagain on Mar 11, 2020 17:16:59 GMT
Hi gents, I removed the gear knob on my P5B over the weekend and found it held together with what appears to be windscreen sealant. I measured up what I think should be a spacer with the following dimensions: OD 3/4 ID 1/2” UNF By 5/8 long My idea is to glue this into the knob. Is this how the knob is supposed to be put together? Mine was all goooey when I took it off and as Harvey says it is just a bit of rubber hose. I did not realise that and paid a lot for a bit of rubber that was not even cut straight !
Post by Brendan69 on Mar 11, 2020 18:02:44 GMT
I also noticed last year at the car shows particularly the very hot days my knob also became floppy and sticky and unresponsive but as things cooled down it became hard and firm again. LOL
