Post by park01 on Mar 12, 2008 19:26:04 GMT
Hi all
the cables which run front to rear(ie follow the sill to the rear one side battery the other side do the lights heated rear windcreen). My car was part restored when i got it and has had a lot of welding in thoose areas were the seat base and sill and floor pan meet. Do the wires go through the conerer of the vertical frame on the floorpan which holds the seat swabs where it meets the sill and floor pan? A pic would be good.
Post by Phil Nottingham on Mar 12, 2008 19:35:16 GMT
No - they up around the do post/top rear wheel arcc under trimmed steel panels .They then go iti the boot at top LH corner jusr to the side of the petrol. Tank. As the HRS was an extra cost option BL were too cheapskate to build the cable into the manin loom and it was just taped to the other two cables.
I can get a picture at weekend as my spares car is outside but its usually too dark etc at this time of year when I get home
Post by park01 on Mar 13, 2008 19:20:50 GMT
Hi Phil
thanks for the reply. Pic would be great of both sides. On the near side the loom must go though the panel which supports the rear seat swabs to got to the rear heater?
karl
Post by johnwp5bcoupe on Mar 13, 2008 19:30:14 GMT
This is a pic of a Coupe breaker at David Greens some of the info for you As you can see the cables go round the wheel arch under the trim
Post by Phil Nottingham on Mar 13, 2008 19:48:33 GMT
I will show you pic with trim removed at the weekend!
Post by park01 on Mar 14, 2008 15:27:46 GMT
Thanks for the pic. I didnt know what trim bit (covering the cable) being refered to has I didnt dismantle the car. The trim bits are in my loft i had often wondered what they were for.lol. Looking at the pic the zig zag shape covered with material goes in first(does the cable go under this?) then the cable cover trim after then the beading?
thansk again Karl
Post by johnwp5bcoupe on Mar 14, 2008 17:00:17 GMT
Thanks for the pic. I didnt know what trim bit (covering the cable) being refered to has I didnt dismantle the car. The trim bits are in my loft i had often wondered what they were for.lol. Looking at the pic the zig zag shape covered with material goes in first(does the cable go under this?) then the cable cover trim after then the beading? thansk again Karl The cables go under the trim I have squiggled in Red the white squiggle is the feed to the cig lighter rear heater etc I am sure Phil will give you some good pics over the weekend.
Post by Phil Nottingham on Mar 24, 2008 23:05:40 GMT
Sorry I took this the other weekend - its under the trim behind the rear seat back after removing both items. The two separate cables are not standard
