Post by bristol406 on May 20, 2020 8:43:59 GMT
The workshop manual says to remove the window frame and glass in order to remove the winding mechanism. I wondered if it was actually possible to remove the mechanism by just holding the glass in the up position somehow.
Post by Phil Nottingham on May 20, 2020 9:15:25 GMT
I have never managed it - a fiddly job and you need thin strong hands!
Post by bristol406 on May 20, 2020 9:32:21 GMT
Okay, thanks Phil. I guess I'll do it the 'official way'.
Post by p5andrew on May 20, 2020 9:40:18 GMT
Personally I am built like the proverbial brick outhouse with hands sized accordingly and the task is impossible for me without dismantling the frame! However, one of my engineers has "ladies hands" and could just manage it. It therefore depends on how you are constructed!
Post by Brendan69 on May 21, 2020 7:24:21 GMT
The workshop manual says to remove the window frame and glass in order to remove the winding mechanism. I wondered if it was actually possible to remove the mechanism by just holding the glass in the up position somehow. In the past when i have done this job on other cars with wind down windows i just used to put a length of thin wood inside the door in the upright position to help keep the window full up while i fiddled with the rest. Its worth a try. Regards,
Post by johnwp5bcoupe on May 21, 2020 8:44:21 GMT
The workshop manual says to remove the window frame and glass in order to remove the winding mechanism. I wondered if it was actually possible to remove the mechanism by just holding the glass in the up position somehow. It can be removed/replaced with the frame in position it's fiddly as Phil says but doable
Post by bristol406 on May 21, 2020 21:27:33 GMT
I'll give it try with glass held at the top. If it works, great. If not, I'll bite the bullet and remove the frame.
