lutz
Post by lutz on Jul 13, 2020 12:38:27 GMT
Dear Sirs, I finished the restoration of my Rover P5 B coupe with the blessing og the german TÜV engineer and I am now in the trial period. The engine is running smoothly and accelarete good. At 87 miles per hour (78 miles/h measured with GPS) and above, I notice that in the same accelarator pedal position the engine has a smal power loss for a short time. Shortly after, the engine accelarate again. This behaviour is so short, that the travel speed do not change. Did you observed such behaviour at a Rover V8-engine in the past? I will gladly accept any further hints or pointers. Finally, I must point out that this Rover has an electrical fuel pump, which is connected tot he reserve line. Best regards Lutz Kopperschmidt
Post by Phil Nottingham on Jul 13, 2020 15:46:09 GMT
May be a fuel supply problem eg tank strainer? What ignition arrangements have you? OEM standard points or electronic
