Post by djm16 on Oct 13, 2020 8:48:03 GMT
This is a real request for help. While stripping down the engine compartment of my 3-litre, I came across the following object lying on the floor. It has to have come either from the 3-litre or from a tool I was using on it. Apart from the usual spanners, I have used an impact driver and a pneumatic needle de-rusting tool. Here is the part: It seems to be made of the same stuff that impact sockets are made of, but the two airtools have not been apart, and still work just fine. So I am mystified. Can anyone identify this part?
Post by Ken Nelson on Oct 13, 2020 14:36:35 GMT
It's shaped like a large clevis pin but doesn't seem to have a hole at the end for a cotter pin, so seems probably unlikely. There is an idler pulley for the fan belt that is adjusted on a swivel mount to tension the belt at the front of the engine. It may swivel on a pin, but there'd have to be some way to hold that from falling out. Or perhaps a swivel pin for the bonnet hinges? Otherwise I'd think it would be more likely related to the air tools. Let us know what you find.
Post by Sam Bee on Oct 13, 2020 18:35:30 GMT
It looks like a cotter pin but cannot see any hole at the R/H end for a split pin.
Post by stirlingmg on Oct 13, 2020 19:14:53 GMT
Has it dropped off your trolley jack?
Post by djm16 on Oct 14, 2020 13:33:24 GMT
Thanks for those suggestions. Keep them coming.
Post by lagain on Oct 14, 2020 17:03:13 GMT
Looks like the plunger to lock a door
Post by Chuck Berry on Oct 19, 2020 8:29:47 GMT
If its up front I would go for hand brake linkage part, as above replies have said there should be a hole for a split pin if not marks for a 'C' clip.
