Post by Eric R on Oct 19, 2020 8:36:51 GMT
Is the fuel tank 562175 common to all P5Bs? I might need to restore or replace.
Post by Chuck Berry on Oct 26, 2020 8:04:35 GMT
Eric, not sure on differences if any, but I have a tank from a MK3 if that's any help. I will check part numbers later just in case if I can find them.
Post by Phil Nottingham on Oct 26, 2020 9:53:49 GMT
Yes
Post by Eric R on Oct 26, 2020 10:53:19 GMT
thanks Chuck but looking at the illustration in the parts book everythinglooks to be different or in different places and I did speak to Barry K.
Post by Phil Nottingham on Oct 26, 2020 15:43:57 GMT
The Mk2/3 tank will fit but does not have the spill return inlet the P5B one has. This is not required (or desired) with electric pumps
Post by Chuck Berry on Oct 27, 2020 9:58:47 GMT
Yes I just checked the parts manual. the main difference seem to be the return line but although the drawing is not specific it does look like there is a small difference in the take points. I will treat this tank as a 3ltre only. It was a good job there was a query on this, thank you one and all for the observations.
