rover3l123
Post by rover3l123 on Nov 22, 2020 19:13:26 GMT
I am renovating my armrests as the adjustment is very stiff. After removing and dismantling I see that there are two nylon blocks that move up and down a track. On mine the tracks / blocks were covered in very old looking, viscous grease. I decided to give everything a thorough cleaning and remove all of the old grease. Without the grease the nylon blocks seem to be move much more easily and so I am wondering if the grease should be there at all or perhaps silicone spray would make more sense.
Has anyone renovated these and are there any tips and tricks?
Post by Ken Nelson on Nov 23, 2020 0:25:02 GMT
I redid mine and left the grease off. Silicone spray is a good idea, but once adjusted I haven't changed their position since.
Post by lagain on Nov 23, 2020 16:16:36 GMT
If you have the panels off the doors give the backs of the door locks a good squirt of spray grease and the window mechanisms
