Post by Dr Bob on Jan 18, 2021 16:32:24 GMT
Hi All The Restoration of my Coupe is nearing the final stages - however the Heater Valve is not playing ball: Searching the forum seems to suggest that soaking in Vinegar/Diesel/WD40 for a week is the only options ... Is there a solution to replace with a pattern part/similar thing doing the same job from a different car that has been discovered or can be recommended?
Post by Phil Nottingham on Jan 18, 2021 16:49:35 GMT
Its a standard type used on other cars of the time eg Oxfords etc with just the lever and/or outlet different.
They are easy to service. I have used the new diaphragm from these other valves and also part of the valve body. Have you checked Wadhams as he did one once that fitted straight on
Post by Jens Munk on Jan 19, 2021 9:15:13 GMT
Which heater valve are you looking for? The one for the front heater is plenty available:
The one for the rear is not. It is, as far as I am aware, unique to the P5B and prone to get stuck or leak or both. I just found one on eBay that is supposed to be good, but it is stuck in customs, so I can't tell yet.
Post by Dr Bob on Jan 19, 2021 16:30:34 GMT
Yep - its the rear one... I've just found one on Ebay as well - I hope we haven't bought the same one!
Post by Jens Munk on Jan 21, 2021 9:01:04 GMT
Glad you found the other one on eBay.
Mine has arrived. It is moving and doesn't appear to have leaked. My rear heater is currently blocked off due to the old valve leaking and needs to be reestablished before I can check it out.
Post by Brendan69 on Jan 22, 2021 12:31:22 GMT
After a few days of soaking mine in vinega and other cleaning agents she works perfectly again and no leaks. Nice toasty hot heaters front and rear now on my car plus i also spent the extra monies and renewed all the rubber hoses and alloy pipes with new SS type replacement pipes from the club shop.
A very satisfying job it was and TBH i never understood as to why folk would close off the flow to the rear heaters. It makes no sense at all to have coolant sat in those pipes for years not moving and or drained off. Much better to have the whole system flowing nicely i think personally. The problems only occur due to lack of general maintanance and regular checking of all the pipes.
Post by Jens Munk on Jan 22, 2021 13:28:08 GMT
I would agree, and if my just acquired valve (££) ever starts leaking (I will leave it open), I will simply bypass it. Considering the design of the rear heater, I don't see much if any heat coming out of it when its electric fan is off on warm days. After a few days of soaking mine in vinega and other cleaning agents she works perfectly again and no leaks. Nice toasty hot heaters front and rear now on my car plus i also spent the extra monies and renewed all the rubber hoses and alloy pipes with new SS type replacement pipes from the club shop. A very satisfying job it was and TBH i never understood as to why folk would close off the flow to the rear heaters. It makes no sense at all to have coolant sat in those pipes for years not moving and or drained off. Much better to have the whole system flowing nicely i think personally. The problems only occur due to lack of general maintanance and regular checking of all the pipes.
Post by Jens Munk on Jan 22, 2021 13:53:57 GMT
BTW, I just spotted one more rear heater valve on eBay:
Post by Brendan69 on Jan 23, 2021 16:57:42 GMT
That ebay seller is always selling stuff for our cars on there. Mostly over priced albeit i think the price of that valve is good for something you simply cannot get anymore new.
lutz
Post by lutz on Mar 11, 2022 20:06:00 GMT
Hi there, I hat the Same Problem with the Front Heating Push-pull-Valve. I tried eine vinegar-method, and it Works. I put ist for a week in a Plastik boxand filled ist up with eine vinigar until every unket was floated. After, I flush ist with Hotel water, Duty it and put it again in WD40 for a week. The valveis now Wirkung well without leaking. Best regards Lutz
