rover3l123
Post by rover3l123 on Mar 29, 2021 22:10:44 GMT
I bought some of the old style ignition leads that fit into a side entry distributor cap. Can any advise on how to deal with the ends of the cable that fit into the holes in the distributor cap? Do the pointed screws just penetrate the insulation of the wires, or is it necessary to fit some type of crimped brass connector to the wires before inserting into the distributor cap?
Post by Ken Nelson on Mar 29, 2021 22:37:10 GMT
I believe they just penetrate into the wires. Be sure you push the wires all the way in though.
Post by Phil Nottingham on Mar 30, 2021 11:34:13 GMT
Yes Ken is correct on both points
rover3l123
Post by rover3l123 on Mar 30, 2021 11:38:11 GMT
Thank you both for confirming this. Now all I have to do is to make sure I get the length right on each lead 😀
