jdm
Rover Newbie
Post by jdm on Jun 11, 2021 11:01:21 GMT
i would be very grateful if anyone could advise me on where I could get a pair of front brake calipers for a 1969 P5B. They are Girling make.Or alternatively where could I them refurbished.
Post by p5andrew on Jun 11, 2021 12:24:30 GMT
JRW offer them, I think on a service and exchange basis. Alternatively, I think Gordon at Roverpart of London may well have them in stock. Otherwise, try Ebay as there are often some available there. If using new old stock items, just be aware that the rubbers may well have degraded over time, even out of use; personally I would give them a thorough check before using.
Post by lagain on Jun 11, 2021 16:24:58 GMT
If yours are in useable condition probably best to have them refurbished or do it yourself. Never split the caliper, but before you take the pistons out give the casing a good clean and possibly paint. Use a foot pump to ease out the pistons, get some stainless steel pistons and fit new rubbers and job done !
My brother has used Past Parts in London for brake refurbishments and has been pleased with the results.
Post by davewright on Jun 11, 2021 16:30:42 GMT
I have just sent mine off to shop.roverp6cars.com as they were recommended on this forum. They are a lot cheaper than JRW and Mark has a good reputation. His first car was a P5B.
Post by johnwp5bcoupe on Jun 13, 2021 8:57:04 GMT
Post by djm16 on Jun 15, 2021 13:43:41 GMT
I don't know where this myth of not splitting the caliper came from, but it is a myth. It is very hard to get the pistons in and out and the rubber boot seated with its (now unobtainable) seating ring. The caliper splits easily and makes access to the pistons a piece of cake. To reassemble there is nothing challenging about it. There is an O-ring to seal brake fluid between the to halves, but fitting it is simple as.
New boots, seals and pistons are obtainable from JRW (at least they were 7 years ago).
Post by lagain on Jun 15, 2021 18:43:39 GMT
I don't know where this myth of not splitting the caliper came from, but it is a myth. It is very hard to get the pistons in and out and the rubber boot seated with its (now unobtainable) seating ring. The caliper splits easily and makes access to the pistons a piece of cake. To reassemble there is nothing challenging about it. There is an O-ring to seal brake fluid between the to halves, but fitting it is simple as. New boots, seals and pistons are obtainable from JRW (at least they were 7 years ago). Not a myth, refer to the first paragraph of page 8, section N of the workshop manual. Although it does not give the reason why.
Post by johnwp5bcoupe on Jun 15, 2021 19:09:56 GMT
I don't know where this myth of not splitting the caliper came from, but it is a myth. It is very hard to get the pistons in and out and the rubber boot seated with its (now unobtainable) seating ring. The caliper splits easily and makes access to the pistons a piece of cake. To reassemble there is nothing challenging about it. There is an O-ring to seal brake fluid between the to halves, but fitting it is simple as. New boots, seals and pistons are obtainable from JRW (at least they were 7 years ago). A simple job to split and the Galley Seal is not an "O" ring it has a square profile!
Post by djm16 on Jun 16, 2021 0:12:02 GMT
Post by johnwp5bcoupe on Jun 16, 2021 18:33:54 GMT
Yes the square cut not the quad
Post by johnwp5bcoupe on Jun 17, 2021 7:47:15 GMT
i would be very grateful if anyone could advise me on where I could get a pair of front brake calipers for a 1969 P5B. They are Girling make.Or alternatively where could I them refurbished. David Green also does a refurbish service DAVID GREEN
