Post by jamesh on Jul 4, 2021 21:00:08 GMT
I wonder if this is anything to urgently worry about. I've purchased a 1973 P5B coupe, according to the history file it has had both front and rear screens removed and new rubbers fitted in 2011. The rubber appears to be in good condition although there are patches of rust / rust staining. I don't particularly want to be leaving something that will cause terminal rot, on the other hand if it is something that can safely be left to "watch and wait" Attachment DeletedAttachment DeletedJames
Post by enigmas on Jul 4, 2021 23:34:25 GMT
Unfortunately rust doesn't sleep, especially under a rubber molding. If you want to stop the decay you need to take remedial action.
Post by Mike’S-a-loon on Jul 5, 2021 2:40:22 GMT
Agreed. What you can see is only the edge. Get it fixed asap.
Post by johnwp5bcoupe on Jul 5, 2021 7:47:41 GMT
Sorry to say the seals aren't fitted correctly James and I hope the metal under them is sound? If it were me I would remove the seal and check rust is never just on the edge! what you are seeing is the clips that should be holding the trim so if shortcuts were made fitting the trim?
Post by jamesh on Jul 5, 2021 8:53:12 GMT
Thanks for the replies. It is a shame, but I realise it does need doing. I've got a local (ish) bodyshop who will have a look at it for me soon, they have got a few classics under their belt, so it's not something that will be a complete surprise to them.
I'll keep you all posted.
James
Post by tarnowl on Jul 5, 2021 10:57:19 GMT
Sadly, when I removed my screen front and back, the metal beneath was like lace! I had to remake part of the rear window frame.😬 Don’t wish to frighten you!! Attachment Deleted
Post by Mike’S-a-loon on Jul 5, 2021 11:14:50 GMT
Just for the record, this is pretty normal for P5's, so don't get downhearted about it. The car looks great! There will always be things that need doing, a list of minor and sometimes more major things to do with an old car, but that's the joy of the hobby.
Post by jamesh on Jul 5, 2021 13:09:47 GMT
Just for the record, this is pretty normal for P5's, so don't get downhearted about it. The car looks great! There will always be things that need doing, a list of minor and sometimes more major things to do with an old car, but that's the joy of the hobby. Thanks. I was expecting a fair bit of rust and general bodywork naughtiness in a car that's almost half a century old. I was a bit concerned because of the location. Panels and cills are not as much of a problem as the corrosion is a little more visible. I'm heartened that the glass was removed ten years ago and no mention was made of any corrosion at the time. Since then the car has had very little use and has been in almost continuous dry storage. James
Post by Phil Nottingham on Jul 5, 2021 13:32:29 GMT
Post by Sam Bee on Jul 5, 2021 22:02:53 GMT
Being well on with my 'bare metal' renovation I recently refitted the front screen. During bodywork phase serious work was required to all four bottom corners of the two screens to rebuild them. With an engineering hat on I am surprised at the very poor design, which allows any water that gets under the seal to 'puddle' in the corners as unable to escape. Further to that, refitting the screen was a revelation in poor fitting, requiring masses of mastic all round to attempt to seal the grass in. There is between 8 and 10 mm of 'slop' to the taken up by mastic so is almost guaranteed to leak at some point. Why on earth this was not rectified early on in production heavens knows. The fix is either for the screen to be made slightly larger or, an easier option which still allows for movement of the body flexing in relation to the glass, would be to manufacture the seals to be deeper under the glass to take up most of the 'slop'.
Post by tarnowl on Jul 6, 2021 7:50:59 GMT
Being well on with my 'bare metal' renovation I recently refitted the front screen. During bodywork phase serious work was required to all four bottom corners of the two screens to rebuild them. With an engineering hat on I am surprised at the very poor design, which allows any water that gets under the seal to 'puddle' in the corners as unable to escape. Further to that, refitting the screen was a revelation in poor fitting, requiring masses of mastic all round to attempt to seal the grass in. There is between 8 and 10 mm of 'slop' to the taken up by mastic so is almost guaranteed to leak at some point. Why on earth this was not rectified early on in production heavens knows. The fix is either for the screen to be made slightly larger or, an easier option which still allows for movement of the body flexing in relation to the glass, would be to manufacture the seals to be deeper under the glass to take up most of the 'slop'. Of course, there is also the option of which seal you use. It seems that Scott windscreen seals are often quoted as being the best to fit. Mine are all on standby, longing for the day when they can be reunited with my Rover!😂
Post by Sam Bee on Jul 6, 2021 19:12:34 GMT
Another chap and i have compared the dimensions of the two seals available and there is only a mm here and there between them and the vital dimension, that between the chanel for the glass and the body, is pretty much the same.
