Post by alguy80 on Dec 5, 2021 14:55:03 GMT
Hi everyone.
I need to get at the back of the radio to fit a Bluetooth adapter into the DIN jack. Can anyone offer any tips on the best way to remove the radio?
Post by lagain on Dec 5, 2021 17:04:17 GMT
A very easy job, just remove the clips holding the fabric in place under the radio and remove the fabric, then pull the knobs off the radio and then undo the nuts securing the radio and any others under or behind the radio and it should come out. That is if it is like mine ! If is very different to mine just use a bright light to see how it is fitted. There is not a lot of room behind the radio.
Post by Phil Nottingham on Dec 5, 2021 18:12:59 GMT
A very easy job, just remove the clips holding the fabric in place under the radio and remove the fabric, then pull the knobs off the radio and then undo the nuts securing the radio and any others under or behind the radio and it should come out. That is if it is like mine ! If is very different to mine just use a bright light to see how it is fitted. There is not a lot of room behind the radio. No fabric fitted on 3 Litres but otherwise as George says above
Post by djm16 on Dec 6, 2021 9:48:53 GMT
Perhaps a picture or two of your radio would help.
It has been a few years, but on my 3 litre, I seem to remember a couple of screws under the centre panel pointing vertically upwards need to come out first.
Post by alguy80 on Dec 6, 2021 22:51:57 GMT
Post by alguy80 on Dec 6, 2021 22:58:31 GMT
Post by alguy80 on Dec 6, 2021 23:00:15 GMT
Post by Mike’S-a-loon on Dec 6, 2021 23:22:36 GMT
Does that radio have a din jack?
Post by alguy80 on Dec 6, 2021 23:52:25 GMT
Does that radio have a din jack? It has a 6 pin DIN 1971 Blaupunkt Frankfurt.
Post by Mike’S-a-loon on Dec 7, 2021 2:01:32 GMT
Very nice!
Post by enigmas on Dec 7, 2021 9:12:40 GMT
Perhaps a picture or two of your radio would help. It has been a few years, but on my 3 litre, I seem to remember a couple of screws under the centre panel pointing vertically upwards need to come out first. Yep.👍 Undo those 4 nuts or small studs (nuts fitted on my MK3) and the complete centre section of the dash drops down and lifts out.
Post by alguy80 on Jan 5, 2022 12:12:30 GMT
Morning all, so two small 8mm nuts to remove and the whole unit drops out. I bought a Classentials Deluxe Mono Auto Radio BLUETOOTH Module 6 pin from classentials.
It was literally plug and play would 💯 recommend it if you want to keep the period radio but need some music.
