Post by Welsh Warlock on Mar 16, 2022 15:52:01 GMT
Daft question maybe? Which way does the water pump on the P5B drive the coolant, Into the top of the rad or into the bottom?
Post by lagain on Mar 16, 2022 17:33:30 GMT
Only a guess, but probably in at the top as when the thermostat opens the rad gets hot
Post by djm16 on Mar 17, 2022 0:40:20 GMT
As water based coolant cools, it becomes more dense and sinks to the bottom. However 3-litre radiators (and 3.5 too) have transverse flow - drivers side to passenger side flow. Hot coolant leaves the engine through the thermostat.
Post by Welsh Warlock on Mar 17, 2022 13:51:32 GMT
As water based coolant cools, it becomes more dense and sinks to the bottom. However 3-litre radiators (and 3.5 too) have transverse flow - drivers side to passenger side flow. Hot coolant leaves the engine through the thermostat. So you're saying bottom (driver's side - assuming RHD) to top as opposed to previous post?
Post by Phil Nottingham on Mar 17, 2022 16:18:06 GMT
-Coolant flows out of the stat housing into the top of the rad - down through the rad and sucked into the water pump bottom (inlet) Up through the block under pressure
Post by Welsh Warlock on Mar 17, 2022 22:20:32 GMT
Thank Phil, that's what I figured but just wanted to be 100% sure.
