Post by philhart on Mar 18, 2022 21:32:14 GMT
Hi all
Recent issue with 1971 P5B V8 Saloon.
Sometimes, in traffic or when pulling out of junctions the car staggers and splutters for a while. Almost stalling. Also, recently I get a strong smell of unburnt petrol.
I am assuming a carb issue but open to any other suggestions. What do you all think is my first port of call? Could it simply be mixture?
Many thanks
Post by Phil Nottingham on Mar 19, 2022 6:44:31 GMT
A general service is a good start. Plugs/points/carb balance/filters/mixture. How old is the petrol?
Post by philhart on Mar 19, 2022 10:04:45 GMT
Hi
Thanks for reply - petrol fresh. I think it may be carbs as had an ignition overhaul not long ago.
Ta
Post by djm16 on Mar 19, 2022 12:45:47 GMT
Sounds to me like the float chamber is flooding because of dirt under the needle. I you have an electric pump, then turn it off and run the engine until the float chambers are dry. The sudden inrush of fuel when you turn the pump back on often dislodges the dirt and the flooding stops.
Post by markymark on Mar 19, 2022 17:08:40 GMT
Hi, A while ago I had a smell of fuel and poor running and found that the reserve valve was leaking. I guess sucking air into the fuel lines leading to poor running and the leak causing the smell. Worth having a look under the car - it’s under the drivers seat from memory - as there is a rubber o-ring that can go and might not like the ethanol in fuel these days.
Cheers, Mark
Post by lagain on Mar 19, 2022 17:42:01 GMT
Make sure that the carbs are clean inside and that the pistons are able to slide up and down.
Post by philhart on Mar 19, 2022 22:32:40 GMT
Thanks for all the replies so far
Post by Sam Bee on Mar 20, 2022 20:45:17 GMT
I have flagged up the need to change these 'O' rings due Ethanol degredation. New replacements on offer are all Ethanol proof, alegedly.
