Post by Sam Bee on May 6, 2022 20:50:23 GMT
Refering to fuel pressure from a facet pump. I recently fitted a new pump rated at 6-7 psi. Different rated springs are available for about 4 quid so I fitted one of 4-5 psi. Simple and neat.
Post by enigmas on May 8, 2022 1:46:47 GMT
Just a quick note. You don't want the pump pressure at the upper end of the needle and seats pressure limit.
For example. If the needle and seat has maximum pressure limit of 4 psi set the pump output limit to 3 psi or fit a cheap adjustable pressure regulator. (Refer to my post above, re: Fuel pump pressure regulator.)
