Post by biffofo on May 13, 2022 7:49:24 GMT
hi all just getting ready to fit an EFP and replace the fuel pipes feeding the carbs Im going to need some new brass hose tail ends to do a neat job on it Am i correct in thinking i need 1/4" NPT
Post by Phil Nottingham on May 13, 2022 13:56:17 GMT
Depends on the pump. - NPT is not equivalent to BSP
Post by johnwp5bcoupe on May 13, 2022 13:58:35 GMT
The connections to the carbs are 1/4" ID olives! is that a tapered thread it's hard to tell? it will be a straight connector not tapered as it has to pull up to the olive.
