Post by djm16 on Nov 16, 2023 3:44:56 GMT
Starting with the LucasAir headunit. It hangs from straps under the glove box rail. (ignore the CD/radio and DC-DC converter hanging off the bottom). The parcel shelf I imagine was modified by the dealer installation 60 years ago.
Post by djm16 on Nov 16, 2023 3:47:06 GMT
Lines from the headunit pass under the tool tray through the bulkhead. Thence via the filter, and under the cabin fan motor.
Post by djm16 on Nov 16, 2023 3:50:38 GMT
A close up of the custom filter bracket, designed to utilise pre-existing holes in the inner wing. I tried to keep the AC tubing as far away as possible from the exhaust manifold for obvious reasons. It is a tight squeeze past the top of the radiator.
Post by djm16 on Nov 16, 2023 3:54:53 GMT
The Sanden universal AC pump has more locating ears on it than are needed, so I removed the one nearest the rocker cover to give enough clearance so the rocker cover can be removed. In practice, I have to take off the AC pump belt and lever the pump as far away as possible to get the rocker cover off. Its a PITA. The L piece has been filed away nearest the rocker cover for the same reason. The is a piece of PVC tape still attached from when I last took the rocker cover off: it protects the paint on the rocker cover while removing it. This is about as good a view as I could get of the modified engine mount that the pump is attached to. The pump pivots on two bolts underneath that are a challenge to reach. Belt adjustment is via a sliding bracket mounted to the engine timing cover. Hang on, lets see if I can find an old photo:
Post by djm16 on Nov 16, 2023 4:10:53 GMT
Here it is, years ago when I first modified the AC setup. The pipework around the top of the radiator is very tight.
Post by djm16 on Nov 16, 2023 4:14:05 GMT
Lastly, some details of either end of the condenser unit.
Post by enigmas on Nov 18, 2023 8:06:32 GMT
Thanks for posting both the images and text relating to the A/C in your 3 litre P5 David. Very comprehensive and useful info for those wanting to instal an A/C in their P5. It definitely is a tight installation. Great care has to be taken with the A/C hoses on the tight turns where they enter and exit through panels. I had the high pressure liquid line on one side of my installation gouge a deep groove into one of the hoses due to vibration. It was easier to fabricate a copper line of suitable size and orientation in my case than to replace the hose. These older systems use flare fittings (not O rings like current systems on connections) and it's definitely worthwhile using appropriate sealing solutions on the unions when reattaching them. Refrigerant will leak through the smallest pinhole in a hose or union. Both the use of green UV detectable dye and an inexpensive gas sniffer (Ebay) are useful tools in tracking miniscule refrigerant leaks.
Post by djm16 on Nov 19, 2023 2:53:44 GMT
I don't recall now if any of the fittings were flared, perhaps on the old condensor. I am pretty sure all are now viton O-rings, nevertheless, a non-setting sealant compound was used.
Post by enigmas on Nov 19, 2023 8:09:38 GMT
Both the "receiver/dryer" (black cannister with the attached pressure switch and sight glass) and the underdash "evaporator" are likely to have flare fittings given their vintage.
