Post by ricky8664 on Jan 28, 2024 12:21:48 GMT
Thought it best to create a new thread on this. Cannot get the engine to run at all with the new electronic dizzy coil and leads.
My mechanic and I have spent 6 hours fitting the new dizzy (and re-fitting it) and trying to get the car to start.. Doesn’t even sound as if it wants to fire apart from one almighty backfire that literally exploded the front silencer.
Checked that the dizzy is timed in the correct place by No 1 cylinder & there is petrol getting to the engine.
We are getting one thing that does not seem right. With the ignition switched on we are getting 12 volts at the + terminal on the coil (from the ignition switch) which I did expect. However we are not getting 12v across the coil (i.e. between the + and – terminals. Only getting 0.8v there.
However, we are getting 12 v between the + terminal on the coil and the output (HT) lead from the coil. And this is just with the ignition on, not cranking. Seems like a short within the coil.
Fuel is being delivered BTW. It would not even start with go juice squirted into the carbs, which is how we got it to fire up when first starting the engine last spring. Absolutely dead.
Having taken everything apart twice and re-connected , we took all the spark plugs out and then tested them in their respective plug leads against a good earth.
All of them were producing a very good strong regular spark. However, in between the strong regular sparks, each plug was also producing repeated small sparks at the electrode several times between each big spark. I have never experienced that before. Usually only get the big regular firing spark.
Next time we will be substituting a good coil. But I also think it may be the new electronic dizzy that is faulty.
BTW we have also checked the compressions. Whilst a couple were down at 130psi, most were between 160 and 180 psi, below the stated 180 to 190 psi on a good engine, but still not so low as to prevent a start.
And as I said, it has turned over without even trying to fire or sound like it wanted to run apart from the exploding silencer incident.
I have written to the supplier with the problem but have not yet heard back.
Any suggestions?
If the known good electronic coil does not work, we will take off the rocker covers to make sure all the valves are moving, in case the massive backfire did some internal damage, though we have already used one of those borescope cameras to check the cylinders and could not see anything obviously wrong. And the engine sounds normal turning over.
If that doesn't work, might get my old dizzy rebuilt as an act of desperation.
Any suggestions?
