Post by themetallian on Mar 18, 2024 16:46:53 GMT
After purchasing my 1971 P5B Coupe last year, I've been working away on some of the many many things I need to do to get the car roadworthy again and back up and running, hopefully to see the light of day this Summer perhaps. The first job was a complete brake system rebuild. Many years of the car sat unused with contaminated fluid had left callipers and cylinders seized, brake pipes and reservoir corroded and everything was in a very poor unloved state.
After quite some hours work, I've now replaced all the brake pipes with nickel/copper and new flexi's front and rear, rebuilt the front callipers, new rear cylinders, new master cylinder, reservoir, new servo, discs, pads, shoes and given everything and good overhaul and lubrication. Time then came to bleed the completely empty system and I've tried my best with a air compressor pressure bleeding kit which I thought would enable me to complete the task by myself. Unfortunately, after bleeding, once the brakes are applied (1 or 2 pumps first time to get the pressure up) the brakes stay locked on all round and only release when I undo 1 or the bleed nipples.
Appreciate is difficult to say but what might the cause of this? I thought I had done everything OK but obviously I haven't and have made a mistake somewhere. I even put the old pushrod back on the new master cylinder as I thought this would replicate the original set up. Somehow once the pressure is applied the brakes come up hard very quickly which I thought was a good sign as not spongy at all and meant I had got things right but the fact they don't release means I've got something or things wrong. Any advice on likely stupid errors I might have made in carrying out this brake refresh would be really appreciated. I've run out of knowledge and experience and now have a car I can't move to even take to someone to look at what I've got wrong. Frustrating after many hours and much expense to sort the entire braking system so any advice and guidance would be really much appreciated as I don't know what to do next to try and resolve the problem(s). Many thanks.
