Post by p5andrew on Mar 20, 2024 13:03:34 GMT
Reassembly in progress
Post by enigmas on Mar 23, 2024 8:48:01 GMT
Hi Andrew...why not simply reply to your own initial post so that it becomes progressive, rather than create new topic numbers (eg. Subframe Restoration 1, Subframe Restoration 2, and so on.) for the same project as it progresses.
You can still cut and paste the text from your continuing list of posts into you first topic post, and then delete them. This method maintains all the relevant work that you're doing in one topic post...rather than myriads of posts.
I'm sure an Admin can sort this for you if you find it difficult.
