Post by rov035 on May 27, 2024 11:07:38 GMT
Currently I am replacing the very dim panel lights with LED bulbs.
While there is a definite improvement, I don't consider it to be satisfactory.
The rheostat maximum output is about 9.8V, should it not be 12V for maximum brightness?
Post by Phil Nottingham on May 27, 2024 15:33:43 GMT
The dimmer is a waste of time - just put a simple on-off switch in. It should however give the full 12v at the "step" just before off. Very few LEDs will work with a dimmer anyway. Ours are quite bright with them and these are 15 years old so newer ones are probably brighter?
