Post by westoz on Jun 21, 2024 3:49:39 GMT
Hoping someone in Aus can help me out with a Hobourn Eaton pump for my MK111 p5? Mine has spun the drive pulley off and chewed up the keyway. TIA Tim.
Post by djm16 on Jun 21, 2024 22:53:05 GMT
I don't but I know someone who probably does. I will ask him tomorrow. Post a picture of yours so that I know what I am looking at. COI: mine is a MkIIb and is driven off the generator.
Post by 3litrekiwi on Jun 22, 2024 21:36:26 GMT
My MkIII has the PS pump on the back of the generator too. Perhaps the pump is a modification that a previous owner has done?
Post by MK IA Norway Viking on Jun 23, 2024 8:50:01 GMT
Good morning - the power steering pump was ALWAYS fitted at the rear of the dynamo (which is different from an alternator).
The pump is driven by the dynamo so that a disc piece about 5 - 10 mm thick is placed between the dynamo and the pump, to transfer power from the dynamo to the pump.
This disc is shaped with grooves in it so that one end fits the shape of a connecting piece sitting in a groove in the anchor (spindle) of the generator, and a similar conneting piece fitting in the groove on the the axle driving the pump.
Note the pump is different between the P5 and the P5B, in that it has different fitting lugs. Still, the concept of transferring power from dynamo to PAS pump is the same on both versions.
Post by Mike’S-a-loon on Jun 23, 2024 15:52:09 GMT
The V8 has a completely separate ps pump. Its on the opposite side of the engine bay to the alternator.
Post by westoz on Jun 24, 2024 4:10:49 GMT
Sorry for the confusion. Mine is fitted with a v8 from an sd1. I just assumed they would be the same. Mine has a stand alone pump down low on the passenger side. I do have a spare motor out of an early range rover. Theyook similar pumps apart from the pulley. Anyone confirm if interchangeable? TiA Tim.
Post by Phil Nottingham on Jun 24, 2024 8:46:58 GMT
The pumps are basically the same apart from the the pulley shaft. The rear mounted dynamo driven version has a tang to locate in the special sleeve on the dynamo armature. The pulley version has a keyed taper/nut
