Post by parispp on Jul 1, 2024 6:49:38 GMT
Hi All, Still doing the old girl up and getting to the pointy end. Meanwhile going broke..... In the front between the seats, there appears in some cases to have a console that can hold things (has a lip to stop things flying). Clearly not on manual versions and mine is an auto with column shift. Should be clearly visible in the stock pictures attached. Anyone know what its called and where I can find one?? Cheers Paris Attachments:![](//storage.proboards.com/2572965/thumbnailer/NrAhFkTuHEMwyPtI0FoV.png)
![](//storage.proboards.com/2572965/thumbnailer/ggdXzyoVDsOklDR0OzKy.png)
Post by Phil Nottingham on Jul 1, 2024 20:37:58 GMT
Trinket/console "tray" - our Mk2c has one - not very effective in use,
As far as I am aware it has not been remanufactured so s/h only. Its just moulded fibre padding under the special thin Rover carpet used then which is NLA
Post by parispp on Jul 1, 2024 21:31:05 GMT
OK thank you. The interior is being fully redone at present as it was really damaged. Might see if they can do something similar but better function as its wasted space. would be handy for phone/wallet etc.
Thanks again
Paris
Post by Phil Nottingham on Jul 2, 2024 5:37:10 GMT
You could modify a P5B version?
