Post by Deleted on Nov 24, 2005 20:29:37 GMT
I have started reassembling the engine after the exhaust valve failure and cleaning the rust from the cooling system. Yesterday I installed the water pump and this morning the antifreeze was leaking from the hole in the pump casting. Can anyone suggest a source for a water pump repair kit? My car is a Mk llc with a Westlake head. Thank you in advance. David
Post by stantondavies on Nov 24, 2005 22:02:28 GMT
JR Wadhams provides a repair kit. But be warned. I needed a ten ton press to get the spindle out of the casting. It went with a HELL of bang!
