why?
Feb 14, 2006 19:10:42 GMT
Post by Deleted on Feb 14, 2006 19:10:42 GMT
hi, ive spent the last six months or so getting my 3 litre mk2 back on the road after being layed up for a long while.anyway its always started easily but ive never really driven it far due to lack of mot.today was mot day ,it started easily as always i decided to give it a 30-40 minute run prior to mot and all went well.got to mot garage stopped car and then it wouldnt start again! ended up flattening battery...anyway got a tow home recharged battery and 3 hours later turned car over and it started first time! any ideas why anybody?
why?
Feb 14, 2006 19:32:35 GMT
Post by Phil Nottingham on Feb 14, 2006 19:32:35 GMT
Sticking petrol pump?
How's your brakes?
why?
Feb 14, 2006 19:38:23 GMT
Post by glennr on Feb 14, 2006 19:38:23 GMT
Faulty coil? I remember I had to deliver a car once when I worked in the auction business. After 20-30 minutes of driving it would stop as if it ran out of petrol. After waiting 10 mins it would restart and so on. I was told it was a faulty coil and it would conk out on me. Not a very safe journey. It might be worth checking the easy jobs first.
why?
Feb 14, 2006 20:30:45 GMT
Post by Deleted on Feb 14, 2006 20:30:45 GMT
cheers, brakes are great now phil thanks.whats best way to test fuel pump and coil?
why?
Feb 14, 2006 20:40:03 GMT
Post by Deleted on Feb 14, 2006 20:40:03 GMT
phil,on reflection i checked the petrol pipe into the carb which is clear and glass reservior at the time and they were both full of petrol if the pump was sticking would they be empty?
why?
Feb 14, 2006 21:40:04 GMT
Post by Phil Nottingham on Feb 14, 2006 21:40:04 GMT
No both wil remain full usually - switch to reserve to test (if you have twin pumps) or disconnect the pipe at carb end to ceheck fuel issues
You should be able to hear it ticking as well 1 evet 15 sec or so.
Tesr coil by substitition - as also condensor
why?
Feb 17, 2006 18:20:37 GMT
Post by Deleted on Feb 17, 2006 18:20:37 GMT
phil,its just done same thing again only it did finally start before i flattened the battery. as soon as it didnt start i went to the boot with ignition on there was no click from pump but it did finally start ! earlier today id swapped the pump with a spare one i had which did click when fitted any ideas
why?
Feb 17, 2006 19:06:18 GMT
Post by Phil Nottingham on Feb 17, 2006 19:06:18 GMT
If its pumping petrol it should start - it could be ignition related so try the usual spark related tests.
It may just be dizzy problem eg earthing, condensor, rota arm.
These engines usually start very easily even with numerous faults (even head gasket!)
why?
Feb 17, 2006 19:14:52 GMT
Post by Phil Nottingham on Feb 17, 2006 19:14:52 GMT
Another thought given the lack of use - stale petrol? How old is it? Have you got any additives in?
why?
Feb 18, 2006 10:11:03 GMT
Post by stantondavies on Feb 18, 2006 10:11:03 GMT
Sounds electrical to me. Check the coil connections for integrity and polarity and/or substitute another coil.
why?
Feb 18, 2006 13:32:39 GMT
Post by Deleted on Feb 18, 2006 13:32:39 GMT
petrols good as i cleaned tank etc out,ive got a new coil coming. can anybody tell me what wires go to which terminals on the coil incase ive got them wrong way around
why?
Feb 18, 2006 13:41:07 GMT
Post by Phil Nottingham on Feb 18, 2006 13:41:07 GMT
If you are still positive earth then - ve to Ignition and +ve to Dizzy
why?
Feb 18, 2006 14:57:52 GMT
Post by Deleted on Feb 18, 2006 14:57:52 GMT
phil im still running positive earth but ive got my negative terminal going to the dizzy and the positive is going to the loom which i presume is the ignition! would this cause the symptons im getting?
why?
Feb 18, 2006 15:26:14 GMT
Post by stantondavies on Feb 18, 2006 15:26:14 GMT
That's exactly what I was saying. It results in the symptons described, easy COLD start but absolute b*****r when HOT. Hope it's solved your problem.
why?
Feb 18, 2006 16:41:21 GMT
Post by Phil Nottingham on Feb 18, 2006 16:41:21 GMT
I agree it does make a lot of difference!
