Post by glennr on Feb 26, 2006 21:11:53 GMT
Can anybody be good enough to send me some photos of the sill trims on the car? The more the merrier but close up shots would be very helpful, Plus the measurement from the end of the trim to the end off the sill! This tends to vary.
I have only recieved two contributions and the jury is still out.
Post by lagain on Mar 3, 2006 10:08:48 GMT
The sill trim should be flush with the end of the sill, there should be no gap. Check that the clips are not rusted and that the trim is the correct way up. The wider section should be the lower edge. A problem can occur if there is rust building up behind the front wing as this can push the rear edge of the wing out and distort the trim.
