Post by glennr on Sept 11, 2006 17:04:37 GMT
Post by andymaslen on Sept 11, 2006 18:20:35 GMT
Glenn she's an absolute spanker - you just made me sure that I've chosen the right colour scheme for mine. What tyres do you use please? Cheers, Andy
bigandy
Post by bigandy on Sept 11, 2006 18:29:23 GMT
nice sill trims your house is rather natty too!!!
bigandy
Post by Multi-Tech on Sept 11, 2006 18:31:28 GMT
Looks great, a job well done
Post by glennr on Sept 11, 2006 20:23:48 GMT
Cheers guys. Andy they are UNIROYAL rallye 185 HR 15. They hold the road with no problem, no squeals into junctions/corners. The next job will be to get the leaf springs off and greased and I will then put the WEFCO gators on. Then the engine out for a rebuild and tidy up of the engine compartment. As a West Ham fan the colour is spot on but I could not put a blue roof on her. ;D
Post by Deleted on Sept 13, 2006 11:48:32 GMT
Great Pics ,there's no other car that looks as good as a nice P5b Coupe-great job.
Post by Deleted on Sept 13, 2006 15:53:27 GMT
Cheers guys. Andy they are UNIROYAL rallye 185 HR 13. They hold the road with no problem, no squeals into junctions/corners. The next job will be to get the leaf springs off and greased and I will then put the WEFCO gators on. Then the engine out for a rebuild and tidy up of the engine compartment. As a West Ham fan the colour is spot on but I could not put a blue roof on her. ;D THINK YOU MEAN 15" TYRES DON'T YOU?
Post by glennr on Sept 13, 2006 18:20:11 GMT
Cheers Freddy, my typo mistake. Yes HR15
Post by glennr on Sept 30, 2006 6:50:55 GMT
I thought I would post this one too I need to sort out the wipers as they don't return automatically when you turn them off. A small annoyance but all I can think to do is renew the wiper motor.
Post by stusax on Sept 30, 2006 9:49:29 GMT
Hi Glenn. It looks to me like you just need to take your wipers off the spindles and move them around a bit. Hopefully you won't need to replace the wiper motor. Do your wipers sweep across the screen appropriately?
Stuart
Post by glennr on Oct 1, 2006 15:12:41 GMT
Hi Stuart, yep, done that but I thought they should return when switched off to the wiper clip that sits on the scuttle panel, when they wipe and you turn off they should return automatically to the parked position on the clip. It's a slight problem but otherwise the wipers work fine.
Post by lagain on Oct 1, 2006 20:17:56 GMT
Some really nice pictures, they do look nice in 2 colours, I have to admit ! When the wipers are turned off they should go to the position shown on the photo, then to a vertical position, then drop down and lift off the screen.
It could be that the contacts in the motor are dirty, if you carefully remove the top of the motor the contacts that control the parking position are on the left. Sometimes it can be a problem with the switch
Post by glennr on Oct 1, 2006 20:31:59 GMT
Many thanks. Would you be able to show me (photo if poss) how they should look when parked?
