Post by johnwp5bcoupe on Oct 13, 2006 9:16:05 GMT
Some pics so far:- We "Plod" on the nice bit now the interior the head lining is not a easy job the frame must be pinched 1/4" smaller than the measurement between the center pillars, I used a string and bracket puller if you don't when you put the frame back in the car you get sags! I found out but trial and error! keep it warm and don't pull too hard otherwise you will end up with crows feet! I didn't but if you do you the material is cotton backed you can use steam to shrink it I have been told the material I used is original s88.photobucket.com/albums/k163/johnwp5bcoupe/?sc=1&multi=1&addtype=local&media=image
Post by glennr on Oct 13, 2006 9:32:11 GMT
First Class John. ;D
Post by PatMcCoy on Oct 13, 2006 16:26:31 GMT
John Did you get the headliner threw a door or was the screen out
Post by Deleted on Oct 13, 2006 16:46:06 GMT
You must have a lot of skill to get the results shown in your album.I wish the running gear etc on my car looked as good as yours. I envy you your garage!
Post by johnwp5bcoupe on Oct 13, 2006 18:48:17 GMT
Thanks lads I am learning more each day!! yes you can get the head liner through the front door Pat you have to take out both front seats and the gearbox tunnel cover hide the gearshift or take it off! just in case! take the door stop pin out and it will go through easier than taking a screen out. My garage is bigger than a double crossplies but still to small for a lot of jobs that need sewing machine and tables, not to mention compressor, mig welder, sand blaster etc etc! I was lucky I could use a friends workshop to prep and spray otherwise what a mess!!
bigandy
Post by bigandy on Oct 17, 2006 7:37:43 GMT
she looks good, keep it up
big andy
Post by johnwp5bcoupe on Oct 17, 2006 21:14:58 GMT
Doing the under felt at the moment Big Andy cutting all the funny shaped bits that fit the grooves then sticking the top felt to them 1/2" felt with scissors is fun ;D
Post by Ken Nelson on Oct 20, 2006 3:21:29 GMT
Gorgeous car! Can you use the same overfelt to fill in the groves in the metal floor, or is that a different felt all together? Ken
Post by johnwp5bcoupe on Oct 20, 2006 6:39:37 GMT
Hi Ken thanks the between the groove felt is standard underfelt and will compress to fill the space it matches the original stuff. The top felt is a very dense one and too thick to use in the grooves, they are stuck together as were the original ones messy job but worth it
Post by Ken Nelson on Oct 20, 2006 19:40:46 GMT
Thanks John, I'll be having a go at my interior in the near future, so your pictures are greatly appreciated. Keep 'em coming! Ken
Post by Multi-Tech on Oct 21, 2006 2:44:08 GMT
Looks like you are having fun john Good job well done. Did you get an email from my brother regarding you door cards?
Post by johnwp5bcoupe on Oct 21, 2006 6:29:57 GMT
No must have gone in the "BLACK HOLE" Barry
Post by Multi-Tech on Oct 21, 2006 10:33:05 GMT
ill sort it now for you, SORRY
Post by lagain on Oct 21, 2006 19:46:17 GMT
I do like that shade of blue, it should look fantastic when it is finished
