tyres
Jan 4, 2005 5:39:53 GMT
Post by Deleted on Jan 4, 2005 5:39:53 GMT
i have to buy four new tyres i know that i need 15x185 x? not to sure of the height of the tyre wall size will be fitted to standard 3ltr wheels thanks mqrk
tyres
Jan 4, 2005 19:23:16 GMT
Post by Phil Nottingham on Jan 4, 2005 19:23:16 GMT
These are the "official" equivalent and look quite good although slightly lower that the original X plies.
I have got them on my M2 Coupe and were drasatic improvement as to handling over the X plies.
No more "Sweeney" sound effects going round corners and roundabouts
tyres
May 6, 2005 23:15:18 GMT
Post by Tony on May 6, 2005 23:15:18 GMT
My tyres are x ply Avon Turbospeed 6.70 x 15. I have read somewhere that new rules regarding a tyre's life are on the way. I believe that 5 years is to be the maximum life! Are we really running a serious risk by using older tyres, even if the car is not used regularly? Could anyone kindly let me know the exact radial tyre that closely matches my original x plys so that the car looks well balanced. Exact ordering specifications would be most appreciated. Many thanks Tony
tyres
May 7, 2005 8:09:08 GMT
Post by Deleted on May 7, 2005 8:09:08 GMT
The nearest radial size to the 6.70 x 15 is 185 x SR or VR15. That is all you need to order these
This is just slightly lower use Search this has been debated before within the last 2 months. Even pictures posted to show the effect. Radials are far safer and improve the ride and cornering no end on 3 Litres and 3.5 Ltres cars The proposed old tyre rule was just a rumour and there is no truth to it.
Old tyres are a hazard though partiicularly X plies which are stiffer. Its best not to try to use them one the side walls show cracks
Allan NZ P5b
1971 p5b Auckland New Zealand
tyres
May 7, 2005 10:46:50 GMT
Post by Allan NZ P5b on May 7, 2005 10:46:50 GMT
tyres
May 7, 2005 18:23:17 GMT
Post by richard eglinton on May 7, 2005 18:23:17 GMT
Tony, everything and more you ever wanted to know about tyres for our cars is at the end of that link! My advice to you is to leave your Avons on if they are in good condition unless you drive at high speed in poor conditions in which case you would be better off with radials. I am sure that a top quality x ply such as you have is far better than some of the radial rubbish some people fit on their Rovers The Avon Turbospeed is rated to 130mph and has a max load of 615kg or 1355 pounds.It is a top quality tyre for a top quality car Richard
tyres
May 7, 2005 19:41:01 GMT
Post by Neddy on May 7, 2005 19:41:01 GMT
I heard that the Avon Turbospeed is a tyre that has stood still. It is the same now as it was 30 years ago, rubbish.
tyres
May 7, 2005 20:50:44 GMT
Post by richard eglinton on May 7, 2005 20:50:44 GMT
How can you hear a tyre that is standing still Brilliant quality British made item but if not good enough for you Neddy you could go for a Dunlop RS5 670 x 15 a snip at £139 + VAT and also good for 130 mph but can only carry a mere 560kg Richard
tyres
May 10, 2005 22:37:44 GMT
Post by Tony on May 10, 2005 22:37:44 GMT
Thank you for the info.I have examined my tyres and they look ok. My maximum speed is usually 50mph and my mileage is around 500 per annum. I think I shall stay with the Avons. Thanks for your input. Tony
tyres
Jul 13, 2005 11:53:47 GMT
Post by Ian Conway on Jul 13, 2005 11:53:47 GMT
As my Mk2 Saloon is in the garage having its brakes overhauled, I've decided to change the tyres as well. It turns out the previous owner fitted C-rated 185/80/15 van tyres to the car, no wonder the handling was vague. If I've got it right from the comments above and the previous thread, I should be fine with 205/70/15s even on a 3-litre saloon, yes? Any particular brand? And does anyone have a spare NSR wheel cyclinder or set of rear brake shoes kicking around? Thanks
tyres
Jul 13, 2005 18:28:12 GMT
Post by Deleted on Jul 13, 2005 18:28:12 GMT
Note that P5 and P5b rear brake cylinders are NOT the samne and both are handed. You can upgrade and fit a pair of P5B which are chaeper that P5's
205/70 x 15 are OK on all P5's as to make you will have to have what you can get hold of unless you are very wealthy and are a customer of Vintage Tyres
Let us know what you do please?
tyres
Jul 14, 2005 15:07:37 GMT
Post by Ian Conway on Jul 14, 2005 15:07:37 GMT
Thanks for the info Found the wheel cylinders (JR Wadhams), not cheap but at least they're original As for tyres, JRW were doubtful 205s would fit the standard P5 rims but they have a stock of 185/15 radials, which have got to be an improvement on the 8-ply commercials currently fitted Lastly, can anyone recommend a replacement damper for slightly more sporting use eg classic rallies? Much appreciated Ian
tyres
Jul 14, 2005 16:29:54 GMT
Post by Deleted on Jul 14, 2005 16:29:54 GMT
205/70s are an approved size and they do fit although they are much wider so I prefer the 185.
Van tyres are not strictly insurance company approved as they are not high enough speed rating
tyres
Jul 14, 2005 23:14:01 GMT
Post by Ian Conway on Jul 14, 2005 23:14:01 GMT
I didn't fit the Transit tyres, honest! They were on the car when I bought it six months ago, I didn't even give them a second look at the time -- it's only because I'm overhauling the brakes that I thought about changing the tyres, then I discovered they were the wrong type Doing well so far, leaking fuel filler, no brakes, dodgy tyres... just as well I've only used it for short journeys Anyway, bottom line is I can put 205 radials on the standard steel P5 rims? Don't know how dear Vintage Tyres are, but found a wholesaler with some Bridgestones at £60 a go and Goodyear Eagles at £70 a go -- any suggestions? Ian
tyres
Jul 15, 2005 16:37:12 GMT
Post by Phil Nottingham on Jul 15, 2005 16:37:12 GMT
8-)If you are talking about 205/70's fitted that seems a fair price - I assume you have throughly read the wide ranging opinions ::)on tyres particularly the 205/70's although many owners have fitted these now. You must still notify your insurance company as the direct radial replacement is 185 x 15. They should not load the premium with this modification but its still is one
tyres
Jul 15, 2005 18:16:49 GMT
Post by RichardF on Jul 15, 2005 18:16:49 GMT
I changed to 205/70x15R recentley and paid £46 each and done at my door by E-tyres (www.etyres.co.uk). See my thread under Rovering, Tyres, page 2.
RichardF Southampton
tyres
Jul 20, 2005 18:58:14 GMT
Post by len corfe on Jul 20, 2005 18:58:14 GMT
Hi mark, it's len i had Xplys on my 3L , put radials on and the car drives great .
tyres
Jul 26, 2005 22:16:20 GMT
Post by Ian Conway on Jul 26, 2005 22:16:20 GMT
Hi Richard, Thanks for the tip. I've just tried etyres for the same size as yours, 205/75 x15H and they've gone up somewhat! www.etyres.co.uk/car-tyres-uk/searchresults?tyreWidthId=6&tyreProfileId=2&tyreWheelId=5&tyreSpeedId=2&tyreReinforced=F&tyre6Ply=F&tyre8Ply=F&tyre4X4=FThey only have two types of radial, Bridgestone or Michelin, the first at £70.90 fitted and the second at £81.90 fitted Interestingly both are officially for 4x4 vehicles, even though I checked the box on the search page to indicate that I didn't drive a 4x4. Doesn't seem to be any trace of the economy tyres you mentioned previously -- maybe someone has cornered the market? If I go for five Michelins that's £410, which is a fair whack but ultimately a small price to pay in terms of my family's safety. How did you find the service, the electronic balancing etc, and are you happy with the result? Ian
tyres
Aug 1, 2005 7:42:20 GMT
Post by RichardF on Aug 1, 2005 7:42:20 GMT
Ian,
I have just checked the e-tyres site and find that the tyres have gone up to £50.90 each. That's for the 205/70R x 15 (T speed rating). As said previously, that includes delivery (naturally), fitting, balancing and VAT and also disposal if required of your old ones. So not bad really.
I was more than happy with the work. Just one thing though, booking for 07:45 as I did will wake the neighbours up a bit due to the running of the van's air compressor for a while. Might be better to book for a slightly later time.
