Post by Deleted on May 27, 2007 0:16:32 GMT
Can any1 tell me what this is and what model rover its from either p5 or p5b.. or even both? also any1 know what model this drive shaft is from, Thanks for your time btw these items will be going up on ebay once i know what they are, so keep your eyes peeled.
Post by Phil Nottingham on May 27, 2007 9:56:30 GMT
No 1 are the fuel lines and double electric pump from a P5 Mk2 and Mk3 Saloon/Coupe,
The 2nd one is the entire propshaft/centre bearing assembly but without any measurements only the rearmost part (the shortest bit) and centre will fit any P5/P5B as the front is model specific
Post by Deleted on May 27, 2007 13:21:41 GMT
We must be glad for the knowledge of members like Phil, what would we do without them? Thanks Phil (and others) for all your help and support
Freddy
Post by Deleted on May 29, 2007 15:23:31 GMT
The very same pump appears to be on E-bay at the moment, so presumably the propshaft is from a MkIII auto coupe?
Post by Phil Nottingham on May 29, 2007 16:04:54 GMT
May be but it depends whether manual or auto as well
Post by Deleted on May 30, 2007 15:42:30 GMT
MkIII auto coupe It's on the bootlid for sale further down the page....
Post by Deleted on Jun 3, 2007 16:27:55 GMT
hi thanks for the info guys, reason i was asking was because im clearing out an old garage which had both a rover p5 and a p5b just wasnt to sure which they belong to.
Post by Phil Nottingham on Jun 3, 2007 17:01:22 GMT
So the prop shaft could be either Mk3 or P5B which have different front sections
Post by Deleted on Jun 5, 2007 18:42:02 GMT
another question if i may, is there any diference between a rover p5 fuel pump and a p5b fuel pump
cheers
Post by harvey on Jun 5, 2007 18:46:18 GMT
P5's have an electric pump, P5B's have a mechanical pump. (As standard)
Post by Phil Nottingham on Jun 5, 2007 18:52:57 GMT
...and these electric pumps have not got enough capacity to feed twin V8 carbs at all throttle/load ranges
theroveringmember
Post by theroveringmember on Jun 7, 2007 6:34:45 GMT
Thats good to know. I was toying with the idea of fitting one to our P6B.
Post by johnwp5bcoupe on Jun 7, 2007 9:51:09 GMT
They realy are single pumps one for normal and the other for reserve I suppose if you combined the inputs and used both pumps together they would work unless you have a known good one they were a bit unreliable used to stick a lot on my old Jag
Post by Phil Nottingham on Jun 7, 2007 17:20:48 GMT
Mine is OK on my 3 litre - never get fule vaporisation!
Post by johnwp5bcoupe on Jun 7, 2007 17:58:55 GMT
I think you can now modify them to solid state and do away with the contacts which was the main problem
Post by Deleted on Jun 8, 2007 13:22:28 GMT
...and these electric pumps have not got enough capacity to feed twin V8 carbs at all throttle/load ranges Phil, about 25 years ago, I had a 2 litre Viva GT road rally / sprint car which ran on 2 x Weber 45 DCOE carbs. The mechanical pump fitted to that did not have the capacity to feed those so I fitted a Rover 3 litre SU from a scrapyard which I refurbed before fitting. I never had any more fuel starvation probs even with only one end working. I think you may underestimate the capacity of a good SU. Mechanical pumps were only used I believe because initially the engine came with them from the USA and they are also a lot cheaper.
Post by Deleted on Jun 8, 2007 22:23:08 GMT
as many of you know ive been putting alot of rover p5 / p5b spares on ebay, im now down to my last few bits but once again im not 100% sure what they are, wonder if any1 could id stuff for me.. 1 2 3 4
Post by DanielSheard on Jun 11, 2007 11:52:19 GMT
Trims from a coupe screen. I think they're mostly the rear one but I'm not 100% sure. Last bunch includes some from D pillar.
Post by Phil Nottingham on Jun 22, 2007 10:03:21 GMT
As to capacity of the single SU used with a V8 it will not keep up wit demand in full throttle with a V8 as I tried one once and did not find out until going up a lsteep hill with a hot engine.
Although as with big Jags both sides can be used in tandem the useful P5 reserve facility will be lost.
The SU pump went for a very good price - the diaphragms are like;y to quickly disolve in unleaded though so it was not a good buy
Post by Deleted on Aug 9, 2007 16:23:27 GMT
oh did you watch it on ebay, was was amazed what it fetched
Post by Phil Nottingham on Aug 9, 2007 17:45:35 GMT
Yes - it was not worth that money. i got some parts from the Ebayer
