Post by Phil Nottingham on Jan 14, 2005 17:51:00 GMT
For the last few days after switching off the PC I have had to log in again each time I have switched off again although it stays logged in no matter what site I go into during on periods
I cannot see where the check box is I originally used
Post by David on Jan 14, 2005 18:41:50 GMT
Phil if you click on the login button (top right) you should have a box that opens asking for your username and password. Below this is a check box for permanent log-in.
Once you've logged in the top right hand box should then say 'log out'
Post by Phil Nottingham on Jan 15, 2005 9:04:34 GMT
Done & thanks - I knew it was somwhere
