Post by Roy F on Feb 5, 2005 9:10:29 GMT
How can threads be deleted such as items for sale that have sold or wanteds that have been found? thanks
Post by glennr on Feb 5, 2005 15:57:37 GMT
Hi Roy If you go onto your message you want to delete you will see in the top right hand corner of the message you posted, QUOTE,MODIFY,DELETE you can Delete your message or modify it as you see fit by clicking on these buttons. Hope this helps. GlennR
Post by Roy F on Feb 6, 2005 18:52:33 GMT
I don't have those options appearing unfortunately.
Post by dorsetflyer on Feb 6, 2005 19:23:39 GMT
Roy, I may be wrong on this, but it could be because you are signed in as a guest and not a member.
Post by glennr on Feb 6, 2005 19:51:53 GMT
Well spotted John.
Post by David on Feb 8, 2005 14:23:38 GMT
All the more reason to register
Post by Roy F on Feb 9, 2005 11:58:57 GMT
You know I tried to register before but it keeps coming up saying invalid characters used...I only type my name! I've just tried again but it makes no difference. What have I done wrong
Post by David on Feb 9, 2005 14:05:16 GMT
Try using all lowercase with no spaces, punctuation, &, -_.
Email me if it doesn't work.
Post by glennr on Feb 9, 2005 14:58:45 GMT
Roy I had the same problem. It did not like me using spaces that is why i have GlennR as my username. With a few trial and errors I got signed in. It also after a few hits (although i am permanantly logged in) does not recognise me as a member so I have to log back on, enter my password and the check the box for 'Permanant log in' again. It is only a slight irritation but it allows you (as a member) to modify or delete your messages as mentioned in the above postings ;)GlennR
Post by Eric R on Jul 20, 2008 8:00:53 GMT
Deleting your own messages seems ok - but how do you delete all those replies once you have ended your subject? Answers it seems stay on forever long after the query has been resolved
Post by Phil Nottingham on Jul 20, 2008 8:04:36 GMT
The query and its answer form a valuable database of information - the SEARCH facility is quite good provided the default critera are rest. Very few topics have not been rasied less than twice some regularly crop up and are made stickies
I agree some threads may not be all technical but sifiting through all this and deciding what should go is a big unnexssary job. something you think unimportant may be just waht someone else needs
